Sound come but picture does not see?
parooni
Hello
My problem is errorcode 0x80040218
Which could be as the fault?
Edited by parooni
the video decoder. You could attach a support zip, so we can see if you got any decent decoders installed (but I guess not ;)) or you just install your favorite DVD Player Application. For example Cyberlink PowerDVD or Intervideo WinDVD or so... and then select it's decoders in DVBViewer->Options->DirectX.
the video decoder. You could attach a support zip, so we can see if you got any decent decoders installed (but I guess not :)) or you just install your favorite DVD Player Application. For example Cyberlink PowerDVD or Intervideo WinDVD or so... and then select it's decoders in DVBViewer->Options->DirectX.
Thanx.. Moses Problem solved! I installed K-Lite codec pack ;)
