optica11 Posted January 4, 2008 Posted January 4, 2008 If I use netstream plugin (not stream wole transponder), is it possible change the channel (into the same transponder) in the DVBViewer client??? It doesn't work to me. I only can change if I stream wole transponder... Quote
Moses Posted January 4, 2008 Posted January 4, 2008 of course it's not possible... net stream plugin only streams what DVBViewer shows if you disable "stream whole transponder" => you can only watch what the server watches on the client, no matter what transponder. You could even take VLC, which has the advantage that it automaticaly shows the new stream if the server switches channel. If you want to watch something different on the same transponder, then stream the whole transponder... Quote
optica11 Posted January 4, 2008 Author Posted January 4, 2008 of course it's not possible... net stream plugin only streams what DVBViewer shows if you disable "stream whole transponder" => you can only watch what the server watches on the client, no matter what transponder. You could even take VLC, which has the advantage that it automaticaly shows the new stream if the server switches channel. If you want to watch something different on the same transponder, then stream the whole transponder... thank you moses Quote
