optica11 Posted January 4, 2008 Posted January 4, 2008 Firstly I would like to Know if it is possible watching different channels in every client with HTTPserver, I've try it and all the clients must watch de same channel even with several cards. On the other hand, I've runing three dvbviewers in my computer (one DVBViewer with one different card), I would like to run one HTTPserver for every DVBViewer, but I try it and it doesn`t work, I open the HTTP in different ports but all of them control the first DVBViewer I've run. I'm very interesting in this and I'll be grateful with some help. Quote
Moses Posted January 4, 2008 Posted January 4, 2008 No, this is not possible. HTTP Server uses the COM Interface of DVBViewer and it's only possible to use the COM interface for the first DVBViewer, the others can't offer such functionalities... maybe you should have a look at DVBServer? Quote
optica11 Posted January 4, 2008 Author Posted January 4, 2008 No, this is not possible. HTTP Server uses the COM Interface of DVBViewer and it's only possible to use the COM interface for the first DVBViewer, the others can't offer such functionalities... maybe you should have a look at DVBServer? I've already tried DVBServer, I was trying to run multiple vlc clients, and with DVBServer it doesn`t work, I need DVBViewer and then I need windows...I'm interesting in a home application and I need very cheap clients... Thank you again Quote
