olixelle Posted January 7, 2008 Posted January 7, 2008 Hello all i'd like to know if DVBViewer supports multi-tuner to record a channel and view another ? I think so as it supports PIP... thanks in advance for ur answe Olivier Quote
thehawk Posted January 7, 2008 Posted January 7, 2008 It does it does My experiments are here: http://www.DVBViewer.info/forum/index.php?showtopic=23628 Quote
Tjod Posted January 7, 2008 Posted January 7, 2008 The better way is using only one instance from the DVBViewer. And let the DVBViewer manage the Tuner. Quote
thehawk Posted January 7, 2008 Posted January 7, 2008 How can this be achieved with one instance? Thank you. Quote
Lars_MQ Posted January 7, 2008 Posted January 7, 2008 Well on my system there are one double tuner dvb-t stick, 2 DVB-S2 ond one DVB-S card working happily side by side in one instance of the viewer (at the same time mind you). Quote
thehawk Posted January 8, 2008 Posted January 8, 2008 Nifty Shall I use the GE version for this? Quote
Lars_MQ Posted January 8, 2008 Posted January 8, 2008 No it's the Pro. the GE can't handle the CI. Quote
thehawk Posted January 8, 2008 Posted January 8, 2008 (edited) Thanks mate, checking it out right now EDIT: Sorry my friend but can you please tell me how to do it? Edited January 8, 2008 by thehawk Quote
