Problems with x.081
Russel-Athletic
Hello. I want to try x.081 to demux a pva file.
After night i get a mpr and a mpl file, but how can i convert them to wav?
How do i switch off the error corrections?
Exist there a manual?
Have a look at the tab "audio". There you can convert the audio-stream to wave.
You can't. That's what ProjectX is there for.
Not yet. But you can have a look at Lucike's forum.
Bye, Oliver
Ok i found a way to get a mpa file (don't ask how :)) and tmpgenc is satified with this file. But i have another question.
Klausing says that you can cut with x.081, but i didn't really found an option rather a videowindows. Or can you only split the files?
After selecting a file you must double-click it. Then a preview is displayed and you can set cut-points. After that select "apply and close". The demuxed version of the video will be cut.
Bye, Oliver
Guest tal-grazzja
I used the Project x.084 for demuxing of PVA file for the first time. However it came out that the video and audio lenghts were not of the same size and the audiophile sounded badly the like with echoed sound. Can you please help perhaps with the settings.
Sorry can't help you with that, but wanted to add a point here:
I have gone back to using PVAstrumento for demuxing because I had a few off- sync audio/video results with X.081 whne processing mpegs where some errors needed corrections.
PVAstrumento seems to handle error correction better than x0.81
- Henk
For this kind of questions please use Lucikes Board. There is the offical Board of ProjectX inside! There you can ask the programmer directly!
I think he/they can help you shortly.
If you post there a question ,please post your X.ini and the log of your problematic file aditionally to a good description of your problem.
Here in this board i would only give a hint of this wunderfull demuxing-tool.
Steffen
Guest Oliver
The .ini-file is located in your ProjectX folder. The log-text are the information in the project windows after finishing the operation.
Bye, Oliver
