GetChannelList in c#
Can anyone provide me with a short code snippet(pref in c#) that shows available channels?
I have rather limited experience developing in c#, and now i'm stuck.
I've tried following to get a channel list:
object obj;
DVBViewer.ChannelManager.GetChannelList(out obj);
Console.WriteLine(obj.ToString());
The list seems empty. DVBViewer is running and everything seems fine.
Edited by pär
did u connect to DVBViewer before ?
yes, using:
DVBViewer = (DVBViewer)System.Runtime.InteropServices.Marshal.GetActiveObject("DVBViewerServer.DVBViewer");
and DVBViewer is running.
Apparently, DVBViewer.ChannelManager has a property named "Item"(according to the docs). But my instance of DVBViewer won't recognize this property. It does, however, find the property "Count".
first i'm not sure that u should use out argument for the parameter (out implies that parameter already contains a value i think)
second, chanlist is a 2 dimension array so the tostring method may not work: did u try to browse the object
Oh.
Well, how do i browse it? :wacko:
Thanks for your help.
  • 1 year later...
I used the following to get the channel list:
IDVBViewer dvbServer = (IDVBViewer)Marshal.GetActiveObject("DVBViewerServer.DVBViewer");
IChannelCollection chnCol = dvbServer.ChannelManager;
for (int k = 0; k < chnCol.Count; k++)
System.Console.WriteLine(chnCol[k].Name);
			IDVBViewer m_DvbViewer = null;
		try
			// Try and get the running instance, a COMException is thrown if the class name is not known
			m_DvbViewer = (IDVBViewer)Marshal.GetActiveObject("DVBViewerServer.DVBViewer");
		catch (COMException)
			if (MessageBox.Show("DVBViewer is currently not running.\r\nDo you wish to start it?", "Start DVBViewer", MessageBoxButtons.YesNo) == DialogResult.Yes)
				// DVBViewer isn't running, so start it
				m_DvbViewer = new DVBViewer();
		finally
			if (m_DvbViewer != null)
				object[,] oDvbChannelArray = null;
				object oDvbChannelList = new object();
				m_DvbViewer.ChannelManager.GetChannelList(out oDvbChannelList);
				oDvbChannelArray = (object[,])oDvbChannelList;
You could declare the size of the channel array saving the cast if you wanted to.
