Snoopyseb Posted January 9, 2008 Posted January 9, 2008 Hi everybody, I have a problem with DVBViewer 3.9.1 when I'm watching a H264 channel. it works fine for a few minutes and then the image is jerky but the sound is still working normally. I use Cyberlink H264 video decoder from Powerdvd Ultra, Vista 32, EVR, Nvidia 7950GT, E6600, 2go, SS3600 I tried to change the codecs priorities but it is still the same. Thanks for your help. Quote
Derrick Posted January 9, 2008 Posted January 9, 2008 ..check whether the hardware acceleration is switched on (DXVA). I have a similar hardware and it works alright. Sometimes I experience the same problems but most of the time it runs stable.. Quote
Snoopyseb Posted January 9, 2008 Author Posted January 9, 2008 (edited) You mean in Powerdvd Ultra or in the nvidia control panel? Thanks Edit : Hardware acceleration is on in Powerdvd Ultra Edited January 10, 2008 by Snoopyseb Quote
Snoopyseb Posted January 17, 2008 Author Posted January 17, 2008 Apparently the problem was my nvidia 7950GT which was not working so well and the card was too hot. I will do some more tests soon. Thanks Quote
