Help With Hauppauge 4000 (Jepssen Trio HD)
andreac75
Hello,
I tried to Scan Italian HD channel with Transedit with my Hauppauge 4000 (Jepssen TRIO HD) without success.
It says "no signal".
Can anyone help me ?
I look for a solution in the forum, but i didn't find anything.
Thank You
  • 4 weeks later...
Hello,
Thank You
I was having the same problems using version 3.9.1...solved by reverting to the previous version 3.9.0. Apparently the new version doesn't detect the Hauppage drivers as it should, in fact in the SCAN dialogue (or the one just before scanning), the Unicast and Multicast Network Devices aren't displayed and the Terrestrial and Satellite Devices aren't properly assigned.
Let's hope newer versions address this issue.
