Dvbviewer + harmony 895 remote control
carter
Hello everyone!
It can be used with 895 harmony DVBViewer?
Thanks
Yes it can. If you have an IR-Reciever for example some one that comes with your dvb-card or something like that, and if you have a fitting remote, you can just learn the codes of it and control DVBViewer with it...
Thanks for your reply.
My card is a life view trio with an infrared receiver and a remote control, the problem is that this remote control only works with the program that comes with the card, and it doesn't work with any other.
What can I do? Do I have to buy another infrared receiver?
Thanks.
if there is no other way to recieve the IR commands from thar reciever, then, yes, you should buy anther IR Reciever. Maybe you could look for a MCE Remote. If you learn the buttons of that remote to your harmony, you don't need another software on the pc, just the MCE plugin for DVBViewer.
