chrispazz Posted January 14, 2008 Posted January 14, 2008 Only to inform that Sky italy is no more supporting MHW epg trasmissions. If it will be possible to add the new standard italians will be happier! Bye Chris Quote
Lars_MQ Posted January 14, 2008 Posted January 14, 2008 well, we have no idea what the "new standard" is... Quote
The Gus Posted January 14, 2008 Posted January 14, 2008 well, we have no idea what the "new standard" is... OpenTV for which, afaik, there's no known way to descranble it, so no plugins nor utilities at this time. I really would like to be contaddicted on this :-) My suggestion is to use the really slow xmltv way. damn! Quote
Lars_MQ Posted January 14, 2008 Posted January 14, 2008 I really would like to be contaddicted on this Not by me. Quote
The Gus Posted January 14, 2008 Posted January 14, 2008 Not by me. I really hope someday someone will discover the way to decrypt opentv epg stream. Until then, we really have lost a great feature for our htpc's Quote
Moses Posted January 15, 2008 Posted January 15, 2008 why is it called "Open" when it's scrambled and therefore closed? Tz.. Quote
robert4ever Posted January 24, 2008 Posted January 24, 2008 This is a very fast grabber EPG for Sky Italy , but the xml file output is not compatible with plugin ImportXMLTV for DVBViewer; In someone wants to try .... Quote
daniele Posted January 28, 2008 Posted January 28, 2008 It seems very nice! May I ask wich program is supposed to use this xml format? I believe it's quite simple (for someone ) to translate the files in a compatible format. Isn't it? Quote
Tjod Posted January 28, 2008 Posted January 28, 2008 Tay Auto Import XMLTV http://www.DVBViewer.info/forum/index.php?showtopic=20539 Quote
