Problems whith burning CD Image files
SLStefanov
I made SVCD-s from DVD (The two towers) with DVD2SVCD - 1 audio, 2 subtitles - and it made 3 CD Images files. The first two (each of them) are bigger then the third. I burned first two without any problems, but I can't burn the third. Where is the problem?
we dont know:
which programm you are using,
which error you get
and so on .......
We are not clairvoyant's ......
