Cinemannix Posted January 15, 2008 Posted January 15, 2008 [sATTYPE] 1=4000 2=Kabel (KabelBW) [DVB] 0=60 1=112999,3,6899 2=120999,3,6899 3=345998,3,6899 4=345999,3,6899 5=353999,3,6899 6=361999,3,6899 7=369998,3,6899 8=377999,3,6899 9=385998,3,6899 10=386001,3,6899 11=394002,5,6899 12=402000,5,6899 13=409998,5,6899 14=410000,5,6899 15=417998,5,6899 16=417999,5,6899 17=426000,5,6899 18=434000,5,6899 19=449999,5,6899 20=457999,3,6899 21=465998,3,6899 22=617999,5,6899 23=625999,5,6899 24=633999,5,6899 25=642000,5,6899 26=649999,5,6899 27=658000,5,6899 28=665998,5,6899 29=673998,5,6899 30=674000,5,6899 31=681999,3,6899 32=689999,3,6899 33=697998,3,6899 34=697999,3,6899 35=705999,3,6899 36=713998,3,6899 37=714001,3,6899 38=721998,3,6899 39=721999,3,6899 40=729998,3,6899 41=729999,3,6899 42=737998,3,6899 43=737999,3,6899 44=745998,3,6899 45=746003,3,6899 46=753998,3,6899 47=753999,3,6899 48=761998,3,6899 49=761999,3,6899 50=769997,3,6899 51=770004,3,6899 52=777998,3,6899 53=777999,3,6899 54=785997,3,6899 56=786000,3,6899 57=793998,3,6899 58=793999,3,6899 59=801998,3,6899 60=801999,3,6899 -------------------------snip------------------------- Hoffe geholfen zu haben. Gruß Cinemannix Quote
Tjod Posted January 15, 2008 Posted January 15, 2008 Noch besser wäre eine .ini in einem .zip Archiv in diesem Topic http://www.DVBViewer.info/forum/index.php?showtopic=20222 Quote
Merauder Posted February 20, 2008 Posted February 20, 2008 Hallo, kann mir einer kurz sagen wofür die Zahl 3, 5 oder 0 in der Transponderliste stehen? 53=777999,3,6899 oder 11=394002,5,6899 Danke im Vorraus... Gruß Merauder Quote
ditzen Posted June 16, 2013 Posted June 16, 2013 Neue Transponderliste seit 12.Juni 2013:[sATTYPE]1=40002=Deutschland: KabelBW[DVB]0=781=114000,5,6900,|KabelBW2=122000,5,6900,|KabelBW3=130000,3,6900,|KabelBW4=140250,3,6900,|KabelBW5=147250,3,6900,|KabelBW6=154250,3,6900,|KabelBW7=161250,3,6900,|KabelBW8=168250,3,6900,|KabelBW9=175250,3,6900,|KabelBW10=182250,3,6900,|KabelBW11=189250,3,6900,|KabelBW12=196250,3,6900,|KabelBW13=203250,3,6900,|KabelBW14=210250,3,6900,|KabelBW15=217250,3,6900,|KabelBW16=224250,3,6900,|KabelBW17=231250,3,6900,|KabelBW18=238250,3,6900,|KabelBW19=245250,3,6900,|KabelBW20=252250,3,6900,|KabelBW21=259250,3,6900,|KabelBW22=266250,3,6900,|KabelBW23=273250,3,6900,|KabelBW24=280250,3,6900,|KabelBW25=287250,3,6900,|KabelBW26=294250,3,6900,|KabelBW27=303250,3,6900,|KabelBW28=311250,3,6900,|KabelBW29=319250,3,6900,|KabelBW30=327250,3,6900,|KabelBW31=335250,3,6900,|KabelBW32=346000,5,6900,|KabelBW33=354000,5,6900,|KabelBW34=362000,5,6900,|KabelBW35=370000,5,6900,|KabelBW36=378000,5,6900,|KabelBW37=386000,5,6900,|KabelBW38=394000,5,6900,|KabelBW39=402000,5,6900,|KabelBW40=410000,5,6900,|KabelBW41=418000,5,6900,|KabelBW42=426000,5,6900,|KabelBW43=434000,5,6900,|KabelBW44=442000,5,6900,|KabelBW45=450000,5,6900,|KabelBW46=458000,5,6900,|KabelBW47=466000,5,6900,|KabelBW48=471250,3,6900,|KabelBW49=479250,3,6900,|KabelBW50=487250,3,6900,|KabelBW51=495250,3,6900,|KabelBW52=503250,3,6900,|KabelBW53=511250,3,6900,|KabelBW54=519250,3,6900,|KabelBW55=527250,3,6900,|KabelBW56=535250,3,6900,|KabelBW57=546000,5,6900,|KabelBW58=554000,5,6900,|KabelBW59=562000,5,6900,|KabelBW60=570000,5,6900,|KabelBW61=610000,3,6900,|KabelBW62=682000,5,6900,|KabelBW63=698000,5,6900,|KabelBW64=706000,5,6900,|KabelBW65=730000,3,6900,|KabelBW66=738000,3,6900,|KabelBW67=746000,5,6900,|KabelBW68=754000,3,6900,|KabelBW69=762000,3,6900,|KabelBW70=770000,3,6900,|KabelBW71=778000,3,6900,|KabelBW72=786000,3,6900,|KabelBW73=764000,3,6900,|KabelBW74=802000,3,6900,|KabelBW75=810000,3,6900,|KabelBW76=818000,3,6900,|KabelBW77=826000,3,6900,|KabelBW78=875000,3,6900,|KabelBW DVB-C_de_KabelBW.ini Quote
VinoRosso Posted June 20, 2013 Posted June 20, 2013 Mit der Transponderliste fehlen bei mir über 200 Sender :-) Kenn mich nicht aus damit, ich hoffe nach nem Blindscan sieht es besser aus..... Quote
MaxB Posted June 20, 2013 Posted June 20, 2013 (edited) Also die von "ditzen" gepostete Liste kann nicht stimmen! Da sind viel zu viele Kanäle drinen... Warum nehmt ihr nicht einfach TransEdit, tragt 2-3 "sichere Frequenzen" (z.B. 346, 354, 362 MHz mit Modulation "QAM 256" [oder ggf. "Auto"], Symbolrate 6900) ein und drückt "Update"? Als Resultat scannt TransEdit die NIT und erstellt euch so eine aktuelle Transponderliste für das Kabelnetz. Dieser Liste dann einen Namen geben und speichern. Einfacher geht es nun wirklich nicht. Da mich die aktuelle Belegung von Kabel BW auch interessiert wäre ich für ein entsprechendes Posting dankbar Falls es nicht klappen sollte, einfach weiter fragen... Edited June 20, 2013 by MaxB Quote
cook Posted June 20, 2013 Posted June 20, 2013 Durch die verdammte Senderumstellung benötige ich eine aktuelle KabelBW.ini Datei. Die oben aufgeführte, lässt sich bei mir nicht importieren. Oder: Welche Frequenzen muss ich eintragen um bei einer Blindsuche alle Kanäle zu finden? Vielen Dank im voraus für Eure Hilfe. Quote
Tjod Posted June 20, 2013 Posted June 20, 2013 Nimm eine Transponderliste wo 1-2 Transponder passen und "Gründliche Suche" im DVBViewer Pro http://de.DVBViewer.tv/wiki/Sendersuchlauf#Gr.C3.BCndliche_Suche Oder aktualisiere die Liste mit TransEdit, eine Liste wählen wo ein paar Transponder passen und dann oben Scan > Update Quote
VinoRosso Posted June 21, 2013 Posted June 21, 2013 Werd das bei Gelegenheit mal machen, wusste nicht das man ne Transponderliste so einfach aktualisieren kann :-) Ich hab gestern noch die Sender die mir persönlich gefehlt habe gefunden, nachdem ich einige Frequenzen aus der obigen Liste noch manuell mit QAM 256 gescannt habe. Mit QAM Auto wurde die nicht gefunden. https://www.kabelbw.de/kabelbw/cms/downloads/kabel-bw-programmuebersicht.pdf hier findet man eine Übersicht welcher sender auf welcher frequenz zu finden ist, allerdings steht da nichts zu den QAM werten oder der Symbolrate. Quote
PeterF Posted June 21, 2013 Posted June 21, 2013 https://www.kabelbw.de/kabelbw/cms/downloads/kabel-bw-programmuebersicht.pdf hier findet man eine Übersicht welcher sender auf welcher frequenz zu finden ist, allerdings steht da nichts zu den QAM werten oder der Symbolrate. Hier findet man alle benötigten Angaben. PeterF Quote
atmoandi999 Posted June 21, 2013 Posted June 21, 2013 Hier die aktuelle Transponderliste für KBW Stand 21.06.2013: [sATTYPE]1=40002=Deutschland: KabelBW[DVB]0=411=114000,5,6900,|KabelBW2=122000,5,6900,|KabelBW3=130000,5,6900,|KabelBW4=346000,5,6900,|KabelBW5=354000,5,6900,|KabelBW6=362000,5,6900,|KabelBW7=370000,5,6900,|KabelBW8=378000,5,6900,|KabelBW9=386000,5,6900,|KabelBW10=394000,5,6900,|KabelBW11=402000,5,6900,|KabelBW12=410000,5,6900,|KabelBW13=418000,5,6900,|KabelBW14=426000,5,6900,|KabelBW15=434000,5,6900,|KabelBW16=442000,5,6900,|KabelBW17=450000,5,6900,|KabelBW18=458000,5,6900,|KabelBW19=466000,5,6900,|KabelBW20=546000,5,6900,|KabelBW21=554000,5,6900,|KabelBW22=562000,5,6900,|KabelBW23=570000,5,6900,|KabelBW24=610000,3,6900,|KabelBW25=682000,5,6900,|KabelBW26=690000,5,6900,|KabelBW27=698000,5,6900,|KabelBW28=706000,5,6900,|KabelBW29=730000,5,6900,|KabelBW30=738000,5,6900,|KabelBW31=746000,5,6900,|KabelBW32=754000,3,6900,|KabelBW33=762000,3,6900,|KabelBW34=770000,3,6900,|KabelBW35=778000,3,6900,|KabelBW36=786000,3,6900,|KabelBW37=794000,3,6900,|KabelBW38=802000,3,6900,|KabelBW39=810000,3,6900,|KabelBW40=818000,3,6900,|KabelBW41=826000,3,6900,|KabelBW DVB-C_de_KabelBW.ini Quote
Andy1967 Posted June 26, 2013 Posted June 26, 2013 Wie kriege ich die von Transedit gefundenen Sender (habe die obige ini-Datei genommen) in den Senderlisteneditor ? Quote
Andy1967 Posted June 26, 2013 Posted June 26, 2013 Warum habe ich keine Erlaubnis,meinen Beitrag zu editieren ? P.S. Durch Add/Update bekomme ich nur einen kleinen Teil der Sender UMKBW. Z.B. kein Rtl,Sat1,Pro7,Vox,etc. Quote
abofinger Posted July 2, 2013 Posted July 2, 2013 Geht mir genauso, Transponderliste aktualisiert, aber RTL SAT1 Pro7 Vox etc. nicht zu finden, bzw. nur hinter irgenwelchen Services versteck, die aber weder Ton noch Bild geben :-( Quote
Griga Posted July 2, 2013 Posted July 2, 2013 RTL SAT1 Pro7 Vox etc. nicht zu finden, bzw. nur hinter irgenwelchen Services versteck, die aber weder Ton noch Bild geben :-( Die Sender liegen auf der Frequenz 114 MHz (S02) mit QAM256 Modulation, die eine höhere Bandbreite als das bisherige QAM64 ermöglicht, aber auch störanfälliger ist. Von einem Entwickler der Firma Digital Devices habe ich letztlich einen Hinweis dazu erhalten: Die Umstellung des S02 von QAM64 auf QAM256 seitens KabelBW wird denen einiges an Support-Anfragen reinspülen. S02 hat bei Dosen, die mit einem Filter TV und Radio trennen Probleme, d.h. der Filter schwächt das Signal und erzeugt obendrein eine starke Schieflage. Die Verschiebung von 113 nach 114 MHz verbessert das zwar etwas, aber nicht viel. Kann also sein, dass es bisher mit QAM64 lief, und jetzt nicht mehr. Moderne Dosen trennen das Signal nicht, d.h. man kann über beide Anschlüsse sowohl UKW als auch das volle TV Frequenzband empfangen. Wenn es jetzt bei KabelBW mit RTL SD Probleme gibt, auf die Dose verweisen. Quote
craig_s Posted July 2, 2013 Posted July 2, 2013 Aha aha, verstehe, das Prob mit den veralteten Dosen hatten wir aber schon vor ca. 2-3 Jahren als es ARD gefiel sich kurzzeitig in eine ultra-niedrige Frequenz einzuquartieren. Hatte mir damals die bestentollsten-neusten drangeschraubt, dann ging es wieder. Jetzt schon wieder neue? Glaub ich kaum, die Dream die an der gleichen Strippe hängt findet alles soweit ich sehen kann. Mit den obigen TransponderListen aber fehlt mir immer SF1 und SF2. Keiner da, der mit seinem Scan halberwegs zufrieden ist und mal seine Senderliste hier preisgibt? Wäre supertoll, danke! Quote
Griga Posted July 2, 2013 Posted July 2, 2013 aber fehlt mir immer SF1 und SF2. Laut dieser Liste befinden sich die Sender auf 738 MHz. Findet TransEdit mit der obigen Transponderliste auf der Frequenz etwas? 1 Quote
craig_s Posted July 3, 2013 Posted July 3, 2013 Alles klar, danke, mit der langen gab es massig Zahlen statt Namen in denen sich der SF versteckt hatte. Servus und einige andere steckten auch noch drin. Mit der kurzen passiert das nicht mehr, alle Namen da. Hier noch die Senderliste (ohne jeden Anspruch auf Vollständigkeit). KabelBW_korr_Channels_2013.zip Quote
abofinger Posted July 4, 2013 Posted July 4, 2013 So, bei mir war es die Anschlussdose. Ich habe sie jetzt ausgetauscht. Bekomme jetzt auch die privaten Sender rein :-)). Quote
luwu Posted July 8, 2013 Posted July 8, 2013 Danke für die Transponderliste. Es gibt zwar eine von Technisat aber die bringt leider nicht das gewünschte Ergebnis. Jetzt habe ich jedenfalls wieder alle Sender! Nochmals Danke! Quote
atmoandi999 Posted July 16, 2013 Posted July 16, 2013 Habe vor einen Mailverteiler einzurichten für die KBW-Leute indem alle Änderungen der transponder und der Kanäle bekanntgegeben werden. Bei Interesse bitte per PN melden Quote
dustan Posted January 13, 2014 Posted January 13, 2014 Bei mir fehlen Pro7, sat1, kabel1, n24, servusTv, sixx. (neuste Liste von Technisat) Danke für die Liste, werde sie gleich mal aus probieren. Quote
atmoandi999 Posted May 4, 2014 Posted May 4, 2014 Neue Liste Stand 04.05.2014 [sATTYPE]1=40002=Kabel BW/Unitymedia (2014)[DVB]0=401=114000,5,6900,|2=122000,5,6900,|3=130000,5,6900,|4=346000,5,6900,|5=354000,5,6900,|6=362000,5,6900,|7=370000,5,6900,|8=378000,5,6900,|9=386000,5,6900,|10=394000,5,6900,|11=402000,5,6900,|12=410000,5,6900,|13=418000,5,6900,|14=426000,5,6900,|15=434000,5,6900,|16=442000,5,6900,|17=450000,5,6900,|18=458000,5,6900,|19=466000,5,6900,|20=546000,5,6900,|21=554000,5,6900,|22=562000,5,6900,|23=570000,5,6900,|24=610000,3,6900,|25=682000,5,6900,|26=690000,5,6900,|27=698000,5,6900,|28=706000,5,6900,|29=746000,5,6900,|30=754000,3,6900,|31=762000,3,6900,|32=770000,3,6900,|33=778000,3,6900,|34=786000,3,6900,|35=794000,3,6900,|36=802000,3,6900,|37=810000,3,6900,|38=818000,3,6900,|39=826000,3,6900,|40=834000,3,6900,| SOFT_Kabel-BW-Unitymedia-2014.ini Quote
Klaus* Posted May 1, 2015 Posted May 1, 2015 Super! Kann ich sehr empfehlen. Jetzt kommen alle meine Sender auf 114000, die weg waren. Herzlichen Dank! Klaus Quote
