License problem with Dvbviewer server only
lighttear
Hi, after several months I decided to pass from 3.6 to 3.9.2 DVBViewer version. I clean uninstalled 3.6 version and installed the new 3.9.2 version. Username and password were correctly retrieved from windows register and DVBViewer 3.9.2 starts correctly.
But if I lunch DVBViewer server, after pressing "start" button, program asks me again username and password; eventhough I reinsert my username and password, if I stop and restart the program, DVBViewer server asks again to put username and password.
Has anyone experienced this ?
Many thanks in advance
What happen if you start the DVBViewer Pro 3.9.2 on this PC?
Hi, many thanks for Your reply,
yes DVBViewer Pro 3.9.2 starts regularly; if I close DVBViewer and start "DVBViewer server" however, only AFTER pressing the "START" button, the program prompts me for username and password; if I fill in the correct username/password pair, the server program tells me nothing; if I fill in intentionally a wrong password, the server program tells me nothing again but it modifies the registry so, next time I start DVBViewer Pro 3.9.2 , it prompts for retyping the correct username/password pair.
It must be said that I am now at work, and I am experiencing this problem on my notebook where I will never need to start the "server" functionality. Maybe the absence of a sat card is causing this.
Thanks anyway
Cheers
Solved: starting "DVBViewer server" funcionality on the machine where sat-pci card resides, I have no more license problem
Edited by lighttear
