OSD: Timer: start/end time
mlehtola
Ok, I love the OSD, but the OSD-Timer has one VERY annoying feature that does not seem to work the same way than in "normal" Timer:
Imagine that it's 11.55pm and the program that you want to record one hour program that starts at 00.05am. DVBV gives start time 11.55 and end time 01.55. You have to go back almost 12 hours with the start time because it's not possible to go over midnight! So I have to click about many times to get the proper hours and about 100x to get the minutes! I use only mouse, there might be better ways if you have rc or something.
Use the numbers on the remote control.
I use only mouse (as I wrote above). Maybe I should switch to rc...but I LOVE the mouse with OSD...
