LiMiT Posted January 21, 2008 Posted January 21, 2008 (edited) Is there any way to set different recording options for each channel? For example, I would like DVBViewer to record all Canal+ channels with DVBSubs and as .TS, while the other channels is suffice enough to be recorded as MPEG? If not, this would make a great feature if it would be implemented. As of now, the settings made in 'Options' for this is global and implies all channels. Edited January 21, 2008 by LiMiT Quote
Lars_MQ Posted January 21, 2008 Posted January 21, 2008 As of now, the settings made in 'Options' for this is global and implies all channels. Yes that is correct. Quote
LiMiT Posted January 21, 2008 Author Posted January 21, 2008 Yes that is correct. This would make a great feature if it would be implemented. Quote
