wiak Posted January 22, 2008 Posted January 22, 2008 (edited) i get corrupt frames in the live transport steam i have no clue why, it happends every 1 min and sometimes the video lags Hardware: Intel CD9500 DVB-T USB 2.0 Stick (MaxLinear MXL5003S Receiver + CE6230 Demodulator) PC: AMD Athlon 64 X2 5000+ OCZ 4GB DDR2 PC6400 74GB Raptor Vista Home Premium 64bit ATI Radeon HD 3870 with Catalyst 7.12 and 8.1 Transport Steam Info: 4mbps MPEG-4 64kbps HE-AAC Norway DVB-T Software Settings: VMR9 Video Mixing Render Default directshow device CyberLink 7.3 Ultra Codecs (DXVA on and off) libfaad2 Wrapper 1.1 Format Detection is not on DVB Source 3.0 DVBViewer 3.9.1 Libfaad2 Wrapper 1.1 sample: http://www.sendspace.com/file/qs8r0p at time > 00:13 you see corrupt frames Edited January 22, 2008 by wiak Quote
Derrick Posted January 22, 2008 Posted January 22, 2008 The stream suffers from continuity errors. Is your reception ok? Try a recording with AV deactivated. Quote
wiak Posted January 22, 2008 Author Posted January 22, 2008 The stream suffers from continuity errors. Is your reception ok? Try a recording with AV deactivated. is it possible to add a OSD that shows the steam errors, audio/video codecs & bitrate? the DVB-Source Settings dosnt tell if there is any errors at all Quote
Griga Posted January 23, 2008 Posted January 23, 2008 the DVB-Source Settings dosnt tell if there is any errors at all It does. Discontinuities = missing data packets = stream errors (mostly due to bad reception or hardware / driver problems). Quote
wiak Posted January 24, 2008 Author Posted January 24, 2008 (edited) It does. Discontinuities = missing data packets = stream errors (mostly due to bad reception or hardware / driver problems). am running it in TSReader Lite and here is what shows up after some time is many TEI and CRC bad? when i move the antenna i lose reception so, it must be that, btw i live near the transmitter (i can see the lights on it in the windows in living room) can DVBViewer devs make a simple application that shows you the pids, channels, bitrate and errors etc like tsreader? didnt i see a TS analyzer somewhere Edited January 24, 2008 by wiak Quote
Griga Posted January 24, 2008 Posted January 24, 2008 can DVBViewer devs make a simple application that shows you the pids, channels, bitrate and errors etc like tsreader? No problem. Didn't take more than one hour, including the manual. Here it is. Quote
Derrick Posted January 24, 2008 Posted January 24, 2008 is many TEI and CRC bad? yes, the only advice I can give, is to delete this particular recording. Quote
wiak Posted January 25, 2008 Author Posted January 25, 2008 (edited) yes, the only advice I can give, is to delete this particular recording. see what happend when i moved the antenna this is over like runnning while i was asleep so its like 4-6 hours aganst the other one with many errors that was like 5 min hehe now i know quality at 40% is bad and low resecption at 40% = corrupt frames and lags Edited January 25, 2008 by wiak Quote
themaster1 Posted January 25, 2008 Posted January 25, 2008 see what happend when i moved the antennathis is over like runnning while i was asleep so its like 4-6 hours aganst the other one with many errors that was like 5 min hehe now i know quality at 40% is bad and low resecption at 40% = corrupt frames and lags There is a software(freeware) which i have recently discovered & it has helped me alot with Ts files See HERE Quote
wiak Posted January 27, 2008 Author Posted January 27, 2008 how many errors are common? anything under 500 is ok? atleast on Continuity Errors Quote
Derrick Posted January 27, 2008 Posted January 27, 2008 ok is zero. Occasional discontinuities can be tolerated. The best way to judge is by playing back the recording Quote
