Nicozaia Posted January 23, 2008 Posted January 23, 2008 Hi My problem is when i switch channel the picture freeces. i can switch channel 1-10 times without any problem but suddenly it happens. it helps to rebuild the graph and then everything works again for a few minutes. I¨ve tried som change renderer overlay vrm 7 vrm 9, increase the channelswitchtime to 2 sek installed the the graph selector. i use xp sp2 but i had the same problem with vista. the codecs is powerdvd 7 and i use firedtv with a ca cabel from comhem sweden. Does anyone recognize this problem. i can't se any post in the forum about this. plz help with this i'e been stucked with this for a month now.. Quote
Nicozaia Posted January 23, 2008 Author Posted January 23, 2008 (edited) I missed the support file sorry and that i use Nvidia 7500 LE graphic card with the latest driver support.zip Edited January 23, 2008 by Nicozaia Quote
Tjod Posted January 24, 2008 Posted January 24, 2008 Did it happened if you remove all Plugins? Quote
Nicozaia Posted January 24, 2008 Author Posted January 24, 2008 Did it happened if you remove all Plugins? Yes. from the moment i had installed it. and i tried to uninstall DVBViewer, firedtv and even xp but the behavior lokks the same. i thought i could be better if i tried some plugins but no . Quote
Nicozaia Posted January 26, 2008 Author Posted January 26, 2008 Yes. from the moment i had installed it. and i tried to uninstall DVBViewer, firedtv and even xp but the behavior lokks the same. i thought i could be better if i tried some plugins but no . Thanka for alla help I solved the problem by using firedtv:s ci instaed of the one DVBViewer uses. strange but it helped. Quote
