Three questions:
Bjur
I'm using DVBV a lot, especially with recordings, but after being switched to the second newest version, I can't get the DVB subtitles to work on the channels. Furthermore I can only see DVB subtitles on recorded Discovery Atlas HD through VLC. If I'm using either DVBViewer or Zoomplayer, I can't get the subtitles, which irritates me, since I'm primary using the two programs.
1. Is there a solution? It can't be right, that I can't see subtitles in DVBViewer any more and why can I see them in VLC?
2. The last couple of times when I have updated to newest DVB I have overwritten my earlier versions, instead of unistall first and afterwards install the newest version, because I haven't found a solution to save my settings when uninstalling the previous version, so I literally have to start over each time. Is there a way to save my settings?
3. When recording HD the commercials comes with and the file gets really big. Which program can I use to cut the commercials and keep the quality and DVB subtitles? Have tried TS package editor, but it took long time, and didn't get any sound with that.
Thanks for the help.
