No CI
titan
I'm not very familiar wiyh this but ok, I will try
exact TV-card modell and useed driver version Technotrend S2-3200 and drivers are 4.4.10.18 with CI interface
type and chipset of the mainboard Asus P5W DH Deluxe 975 X chipset
graphics card and useed driver version - Asus 7600 GT HDMI with latest drivers
I had 3.9.0 version and everything worked fine ,then downloaded 3.9.2 ,deinstalled old version and installed new version . In the begining checked CI support for Technotrend and when everything finished I'm getting the free channels ,but encoded -NO then can not see my CAM ,Show CAM is not active.
Then found 3.9.0 deinstalled 3.9.2 and installed again 3.9.0 but same Show CAM is not active . I have Irdeto CAM with Euro 1080 card.
Any idea how to activate this CI plugin ?
Edited by titan
The problem is that with old version everything was ok , after changing the instalation process changed something and now NO CAM .
The processor is Core duo E 6550 Intel
2 GB RAM
500 GB HDD
I have exactly the same problem here.
The problem came up after reinstallation of the whole system. With older softwre versions everything was fine.
I have the TT S2-3200, newest drivers,
I am on an Abit P35 pro Motherboard and
Geforce 7600 GT HDMI graphics card.
rgds,
Charly
please start the viewer with the -debug commandline tune some channels and then post the support.zip again. it will contain a debug.log, maybe it shows what going wrong in your system.
oh one thing, maybe you need to install the MS VC support files. you can find them in the download list of the setup.
Sorry , I'm not a specialist , just a simple user .Could you ,please, explain better . I need to run this tomorrow to record something important for me .Thank you very much .
When I'm installing the program there is some options to install CI support and I'm doing it , but after I run the program again I can not see the CAM. I have now 3 different CAMs - original Irdeto, Dragon 4.1 and Alphacrypt.
How to start debug command line ??
Well let's see. If you select the CI option is there maybe something on the page that has a "MS VC" in it?
You don't need to be an expert in DVB to read properly and do a little thinking of your own... >_<
OK, thanks , I manage to run EXQI with my smart card , but there is a new problem now .When I run some HD channel to record after 5-10 minutes the program blocking and I lost my favorite records ...Any idea ?? Why this program always stop after some minutes ..I can not use it at all ....
Edited by titan
