Automatically export EPG > xml
Carl Dickson
Hi, Im wanting to automatically export the epg data to a xml file, whats the best way of doing this?
Thanks
There is no way. you have to use the interface of the COM server to get the epg and the create a xml out of it.
Well it worked, I managed to do it with the com object. It automatically exports the epg into a XML file so i can import the data into Windows Media Center.
Edited by Carl Dickson
Thats simular to what i did, besides how do you get at programe's Category?
Cheers
Via the category id and then via language file. I can't remember the name of the file and I'm not at home ate the moment
