Pohanka Posted January 28, 2008 Posted January 28, 2008 When I start and stop DVBViewer the windows setting of "Always show power management icon" is disabled. The DVBViewer change this setting (it uncheck the setting). support.zip Quote
Lars_MQ Posted January 28, 2008 Posted January 28, 2008 The viewer does not change or even touch this setting. Quote
Pohanka Posted January 28, 2008 Author Posted January 28, 2008 The viewer does not change or even touch this setting. It is very strange because when I check this icon, close the window, start the DVBViewer, stop DVBViewer and open the Power management, it is unchecked. I am also using Girder 3.2 with DVBViewer COM Control Plugin, DVBTaskScheduler_v2.2.2, and Windows XP home. So, what else should it do? It is 100% repeatable. Quote
Lars_MQ Posted January 28, 2008 Posted January 28, 2008 If I remember correctly this was an issue of the graphics card driver. I think we had a user with a similar problem but I'm not sure. Quote
