How do I change channels of the preview window?
Alucard69
How do I change channels of the preview window? Because I can toggle preview on, but I can't change channels in the little window. So what't the purpose of having the PiP mode it it's unusable? Please give me a hint.
You have to start PiP and than charge the main window. You can swap picture and/or sound. All possibilities are shown if you pres OSD-blue [F8] if PiP is open and select help.
What do you mean by "charge"? Unfortunately under "blue osd" key I have some other menu like "play, pause" etc. And is it difficult to set it to use by remote control?
