Additional command on exit
lighttear
Hi, I recently upgraded from 3.6 to 3.9.2 DVBViewer release.
With the old version, using the "exit" command through the remote control, and enabling the "additional command" on exit in the general options, both pressing the standby or hybernate choice, first DVBViewer was exiting and THEN standby or hybernate invoked.
Now , with 3.9.2, standby and hybernation are called WITHOUT first exiting DVBViewer, and this causes problem when resuming.
Since in the changelog I don't see any reference on this subject, there is a way to recover the old behaviour ?
Many thanks in advance
L.
L.
Solved: all I had to do was to copy scheduler.exe and scheduler.ini of the old DVBViewer version.
Now works as before.
Thanks everybody
L.
