DVB-T & DVB-S at the same time?
reg666
Does DVBViewer support DVB-T & DVB-S (Hauppauge HVR 3000) at the same time? Or settings has to be changed every time?
Thank you.
Thank you.
i have a hauppauge HVR 4000
and it work OK at the same time dvb-t and dvb-s
i Had just to set this option like sayd me by mabruk
http://www.DVBViewer.info/forum/index.php?...rt=#entry176809
Where are you from ?
how many channel DVB-T you have in DVBViewer ?
you have card similar to the mine so we can be useful one with the other
Thanks for help. It really works! This setting is not explained in official help file.
I am able to receive one Slovak multiplex (5 TV, 4 Radios) and one Austria multiplex (5 TV). I am living in Slovakia near Austria border.
Have a nice day.
Hello,
as far as i know, there is a hybrid Tuner on this card. So you can only use DVB-S or DVB-T at same time. ;)
