antonioc Posted October 16, 2003 Posted October 16, 2003 Hi, I see satellite TV with a CRT projector so is not a good thing have a white TV Logo in the same position for hours, it is dangerous for the CRT. Is it possibile to have a similar function like the Dscaler Logo killer ? If I built a graph with Ffdshow and Ffdshow use the Dscaler logo killer ... does it work ? Thanks Antonio Quote
Technofriend Posted October 20, 2003 Posted October 20, 2003 if you only mean the elecard logo, then you could easily choose another renderer. If you mean real tv-logos, then I have no idea.... but mostly they are seethrough, aren't they... Quote
antonioc Posted October 20, 2003 Author Posted October 20, 2003 I mean real tv logo , like Euro 1080 Astra or Rai 1 Rai 2 ... white and in the same position all the time. I just use Skyavc with Sonic video (Dxva on) and moonlight for audio . I try Ffdshow with Dscaler Logo killer , Logo killer works but I think Ffdshow is incompatible with the satellite video stream. I have green bars with Sonic and half video + other problems with Intervideo. Antonio Quote
Guest Oliver Posted October 20, 2003 Posted October 20, 2003 FFDShow is compatible, but you must select "raw video". It doesn't work with Elecard, though. Try to use the forum search, some months ago some people experimented with FFDShow. Bye, Oliver Quote
antonioc Posted October 20, 2003 Author Posted October 20, 2003 Raw video is selected . With intervideo video decoder (Windvd5) I have the image , but the filters (sharpness, denoise and so on) seem not to work. If I select a dscaler filter CPU usage jumps over 100%. Thanks , I try with a search. Quote
antonioc Posted October 22, 2003 Author Posted October 22, 2003 My last experiments, using plugin (Thanks ) for custom graphs. I see that Ffdshow works well only with some channels. * Most of Astra channels seem ok. ** Most of Hotbird channels aren't ok. Skyavc + Sonic video = only green bars Skyavc + Intervideo (Windvd5) ok *green bar on the right of the picture **half image , or aspect not correct Skyavc + Cyberlink (Powerdvd 5) crashes very often * Ok ** corrupted image Not so good results . Any idea ? Bye Antonio Quote
Klausing Posted October 22, 2003 Posted October 22, 2003 It looks like a problem of your directshow! For me all this filters (your combinations) runnig properly Quote
antonioc Posted October 22, 2003 Author Posted October 22, 2003 @Klausing do you mean with Ffdshow ? Without Ffdshow all this combinations works great. Which version of Ffdshow are you running ? Quote
