thenewguy Posted February 1, 2008 Posted February 1, 2008 can i have more than 1 DVBViewer on one PC? br thenewguy Quote
hdv Posted February 1, 2008 Posted February 1, 2008 Hello, yes it's possible -> http://www.DVBViewer.info/forum/index.php?...st&p=166690 Quote
thenewguy Posted February 1, 2008 Author Posted February 1, 2008 Hello, yes it's possible -> http://www.DVBViewer.info/forum/index.php?...st&p=166690 thanks Quote
thenewguy Posted February 2, 2008 Author Posted February 2, 2008 it works fine but now i have a grafik problem can only see preview on one and full frame the other br Quote
hdv Posted February 2, 2008 Posted February 2, 2008 Hello, have you use Overlay as Renderer in directX options, in both DVBViewer? Change one or both to VMR7 or VMR9. It can be necessary to tick the "NVidia VMR Fix" Quote
thenewguy Posted February 2, 2008 Author Posted February 2, 2008 Thanks, now it's up and running thank you very very much br Quote
