jekuli Posted February 4, 2008 Posted February 4, 2008 Hi, Is there some function/feature that can be used while in OSD mode (htpc using just remote) to cancel scheduled recording from EPG? Quote
thehawk Posted February 4, 2008 Posted February 4, 2008 Don't want to start a new thread as I have a very simple question: How can I (using only a remote) get a list of ALL channels in alphabetical order? Thanks. Quote
jekuli Posted February 4, 2008 Author Posted February 4, 2008 Try the OSD-Timer window. Thank you, that was the place were unwanted scheduled recordings could be removed. Thanx again! (for future version, an option to unschedule recoding right from EPG would be nice addition. For example, when trying to re-schedule program (red-button), DVBViewer would tell that this show is already scheduled and would ask if user would like to de-schedule the show) Quote
tjabbaranx Posted March 6, 2008 Posted March 6, 2008 I have a similar question. How to cancel scheduled recording from OSD when its halfthrought the program? And still keep the recording? Make any sence? I mean, i scheduled the tvshow Lost and i come home when ,say, 10 minuters left of the show. I notice that the show is finished (commercial) and i want to stop the scheduled recording because there is another movie, in another transponder, i want to record right that minute. How do i stop and save Lost? i hope you undersatn my question Or have i missed something essential? Quote
Jnmarczi Posted March 6, 2008 Posted March 6, 2008 hi, similar question, but the same solution... just disable the timer at the osd-timer window. the active recording will be stopped... Quote
