antdude Posted February 5, 2008 Posted February 5, 2008 See http://img525.imageshack.us/img525/5192/sn...04233037mi0.jpg ... Is it normal for me to be seeing that top part. I was told this is for "excessive vertical blanking (more than 20 lines) which pushes the vertical interval, along with whatever test signals, SID, closed-captioning, etc., down into visible range" from alt.tech.hdtv newsgroup. Is there a way to cover this up? I have no problems with HD ones. Thank you in advance. Quote
jf2020 Posted February 5, 2008 Posted February 5, 2008 (edited) See http://img525.imageshack.us/img525/5192/sn...04233037mi0.jpg ... Is it normal for me to be seeing that top part. I was told this is for "excessive vertical blanking (more than 20 lines) which pushes the vertical interval, along with whatever test signals, SID, closed-captioning, etc., down into visible range" from alt.tech.hdtv newsgroup. Is there a way to cover this up? I have no problems with HD ones. Thank you in advance. This is perfectly normal. DVBViewer displays the full image. Just use the zoom control to stretch the image a bit. You won't notice the difference (after all a normal TV does a much bigger cropping) but you will get rid of those white lines. Edited February 5, 2008 by jf2020 Quote
antdude Posted February 5, 2008 Author Posted February 5, 2008 This is perfectly normal. DVBViewer displays the full image. Just use the zoom control to stretch the image a bit. You won't notice the difference (after all a normal TV does a much bigger cropping) but you will get rid of those white lines.Is there a way to have DVBViewer autozoom in and out between these? I noticed each one can be different sizes. Obviously, I don't want to zoom in and out for HD ones since those are fine. Quote
jf2020 Posted February 6, 2008 Posted February 6, 2008 Is there a way to have DVBViewer autozoom in and out between these? I noticed each one can be different sizes. Obviously, I don't want to zoom in and out for HD ones since those are fine. You're not the first one to ask. AFAIK this feature is not yet in... Quote
antdude Posted February 6, 2008 Author Posted February 6, 2008 You're not the first one to ask. AFAIK this feature is not yet in...Ah, OK. Quote
