Possible bug in DVB Recording Server 1.4.0 Beta
kapa
I used 1.4.0 recording service + DVBViewer 3.9.1 for about a week. I found some peculiar behaviour:
If the computer was on standby the recordings (ts files) were incomplete or there were no files at all. The computer did wake up from standby on time. And after the recording session the computer started to go on and to standby frequently (10 minutes off then on) I'm using my own Standby Controller which set the computer to standby after some inactivity. If the computer stays on whole time this behaviour didn't occur. Also I downgraded to DVBViewer 3.9.1 and 1.3.5 rec service and the problems disappeared. Have anyone else noticed this behaviour?
Regards,
Kapa
Forgot to add support.zip
here it is. this is from working 1.3.5 + 3.9.1 versions.
Kapa
