User configuration files
avoidz
I know where the Configuration folder is on my drive; I have my channels and favorites backed up, but which file in particular saves my custom keyboard config?
Cheers :rolleyes:
Edited by avoidz
\Remotes\*.remote if you charge your config you should Save it not as default Options>Input>Save.
Thanks for the help, Tjod :rolleyes:
It'd be good if there was an export option for all user settings, similar to Firefox's FEBE extension; like a backup facility.
Also, is there a way to reset the windowed dimensions to the default install state; are those values stored in the user directory, too?
Thanks :blink:
Yes in the setup.xml
to reset them start the DVBViewer with DVBViewer.exe -reset
That's great - thanks again :blink:
