Service and control problem
Everything worked fine with xp. Now I have Vista 64-bit and I cant install or uninstall service. I can see DVBViewer service icon on the bottom right but I can't open it. I tried start it but it stays gray.
I have marked "use rec service"
After installation try comes following error:
Ongelmatapahtuman nimi: APPCRASH
Sovelluksen nimi: DVBVservice.exe
Sovelluksen versio: 1.4.0.0
Sovelluksen aikaleima: 2a425e19
Vikamoduulin nimi: kernel32.dll
Vikamoduulin versio: 6.0.6000.16386
Vikamoduulin aikaleima: 4549be94
Poikkeuskoodi: 0eedfade
Poikkeuksen poikkeama: 00023843
Käyttöjärjestelmän versio: 6.0.6000.2.0.0.768.3
Lokaalin tunnus: 1035
Lisätietoja 1: 7126
Lisätietoja 2: d87d1f791817d741c8f9dcd1d275bf29
Lisätietoja 3: ba8d
Lisätietoja 4: 3fa4a7d2842a9c84f1b33cf3994e6e5b
As written in der readme, the service does only support up to windows XP, so you're on your own...
