control 2 dvbviewers over lan
optica11
If I have 2 DVBViewer instances I would like to be able to change channel in both from another computer over lan. If I use httpserver to do that I can only control the first instance, and someone replies me that the second instance can`t be controlled via another httpserver because COM interface only works in the first instance.
Is there any possibility of use some javascript funtion to control the command line in my "server" and change channels in both via cmd: DVBViewer -x¿?¿?¿? (not via COM)
I only want to be able to change channel from httpserver (for example) in both dvbviewers, I'm not interested in httpserver stream.
With the -x parameter you can use all commands from the actions.ini. But you need a tool witch sends the command line things to the DVBViewer.
I don't know if you have understand me...I want to change channel via "remote" use of my command line, I think it's possible adding some java script function to httpserver web. If I open 2 command lines (or with 2 file.bat), I'm able to change channel in each DVBViewer, I want to do it from modified httpserver.
Perhaps command line use COM interface, then how could I assign each httpserver to each DVBViewer??or how can I control both DVBViewer from a single httpserver???
I think COM interface only works in first DVBViewer instance...but I'm not sure...
Edited by optica11
