Nils-H Posted February 8, 2008 Posted February 8, 2008 Hi! I have an odd problem with the MCE remote plugin. A couple of the special buttons does not create any input to DVBViewer. When in learning mode, pressing the My Movies or My Pictures buttons, nothing happens. In MCE, the buttons work just fine. Also, the other special buttons work. What could be wrong? Nils-H Quote
h8red Posted February 15, 2008 Posted February 15, 2008 Hi! I have an odd problem with the MCE remote plugin. A couple of the special buttons does not create any input to DVBViewer. When in learning mode, pressing the My Movies or My Pictures buttons, nothing happens. In MCE, the buttons work just fine. Also, the other special buttons work. What could be wrong? Nils-H Hi I have similar problems, allthough I can´t get a single button on my remote to work with DVBViewer. Latest version. I have downloaded the plugins and have choosen mce2005 (have also tried the others) nothing works. When I look at the configuration all the keymappings are for a keyboard, shouldn´ t it have changed to remote commands ? What am I doing wrong ???? Please advise Quote
Gioxy Posted February 15, 2008 Posted February 15, 2008 AFAIK MCE remote is sensed by DVBViewer as keyboard, not as remote... Quote
marc88 Posted February 15, 2008 Posted February 15, 2008 (edited) When I look at the configuration all the keymappings are for a keyboard, shouldn´ t it have changed to remote commands ? What am I doing wrong ???? Please advise you need to learn the mce buttons first.. click the learn button in the upper right corner, then select your command and push the button on the mce.. then there should be an extra entry (besides keyboard) which is named mce or similar.. afaik the only button you cant map with the mce plugin is the green buttton in the middle.. also @Nils-H if you want to use all buttons you could try the girder version.. you need the girder program, the mce plugin and its DVBViewer plugin.. you should find these and some instructions here on the board.. //edit: girder329b, mce plugin, girder plugin Edited February 15, 2008 by marc88 Quote
Delphi Posted February 15, 2008 Posted February 15, 2008 Maybe this can be helpfull for some of you: http://www.DVBViewer.info/forum/index.php?showtopic=14931 Quote
Andrey123456 Posted August 27, 2009 Posted August 27, 2009 (edited) I have exactly the same promlem. Two buttons, My Movies and My Pictures, do not work and nothing happens in Learn mode. I use XPproSP3 and mce2005 plugin. Had someone found solution? Edited August 27, 2009 by Andrey123456 Quote
SnoopyDog Posted August 27, 2009 Posted August 27, 2009 Hi Andrey! Did you try my plugin or the original one? http://www.DVBViewer.info/forum/index.php?showtopic=28849 The ZIP contains a "normal" version and a "debug" version. Use the debug version only if still some keys are not recognized. The debug version creates a file C:\MCE2005.txt" for still unsupported but recognized keys. If everything works, then DON'T use the debug DLL. Quote
Andrey123456 Posted August 27, 2009 Posted August 27, 2009 Your plugin works just fine. Thank you very much. Some wishes for future versions: It would be very nice to have in plugin settings "antirepeat timeout" parameter, like in TT-Remote plugin. If it is possible of course. Quote
SnoopyDog Posted August 27, 2009 Posted August 27, 2009 If you tell me what anti repeat timeout means - sorry, i'm old and it's late already Quote
Andrey123456 Posted August 30, 2009 Posted August 30, 2009 Antirepeat timeout is a minimal time interval between two commands when you press and hold button for a long time. It prevents processing command twice when a button is pressed just once. Algorythm should be following: if remote command is received - process it, wait for "antirepeat timout", then enable reception of next command. I would like to change this parameter because of two reasons: 1. Prevent multiple action when I press a button once. 2. Possibility to adjust speed of channel switching when I press and hold ch+ ch- Quote
