Nordic EPG
argon
Nordic EPG
Is there anyone who knows if it is possible to catch a seven day (or longer) EPG from satellites for the Nordic channels (Viasat and Canal Digital)? I just get the two closest programs.
Today I´m using o2, and that works well. But if it works directly from the satellites it might be a better solution.
Catch the World,
Argon
Canal Digital using MHWEPG on 12515 MHz (Astra 19.2° E) enable it (Options > EPG/Teletext> Restive MediaHigway EPG)
And stay a moment on a channel on this frequency for example radio FunX.
EDIT:
For Viasat may be on 12054 MHz add it in Options > SieFern/MHW and try it.
Edited by Tjod
Hi Tjod
Thank you for your answer,
But I think this “Canaldigitaal” not is for the Nordic market
Canal Digital is owned by Telenor Broadcast. I guess they have about half the Nordic market (Sweden, Denmark, Norway and Finland). They are distributing (mainly) the channels to this market via Thor 1gV. The channels are located under Telenor or “unknown”. Example of channels are Canal+ Action, Canal+ Hits, Canal+ HD, Kanal 5.
I found a two days EPG from “Discovery Civilization”.
Kind Regards,
Argon
  • 1 year later...
Does anybody found a solution for Viasat 5E EPG? I tried SieFern/MHW but without success.
What it is o2?
Thanks,
Kestutis
