Can't find my HDTV channels..
Bubbi
Hey there.
I have a Technotrend Budget C1500 card.
My PC is a Intel Core 2 Duo 4400E 2.0 GHz
with 2gb ram and a nVidia 6800GT.
And a 40" Humax LCD TV.
I use DVBViewer but i can't get it to find the HDTV channels.
I have tried to use the normal program that comes with the Technotrend card,
and it finds the HDTV channels. It just can't play them.
But DVBViewer just wont find them.
I should be able to find these channels:
PRO 7, SAT 1, Annexe & Astra HD
On this frequency:
762 MHz, Symbolrate: 5776, QAM 256
But when i search that frequency it just doesn't find anything.
I have Cyberlink PowerDVD 7, and have chosen that for H.264.
Please help me.
Small update..
I got DVBViewer to find the channels..
Had to set it to "New Tuning Method" in hardware settings for my TV card.
But.. There's still problems..
When i use PowerDVD's codec i get the sound and a very skipping picture.
I can see the picture, but it lags like crazy. Showing about 1-2 FPS.
When i use FFDSHOW i get a total mess in the picture.
It doesn't lag, i just get a lot of blocking. And can't see anything from the "normal" picture.
Is there a better codec to use ?
