domyrat Posted February 13, 2008 Posted February 13, 2008 (edited) I installed the software, and when i found channels, i tried to change channel or change volume, but it doesnt respond. Buttons are there but dont work. Whats the problem? Tv-card http://www.gigabyte.com.tw/Products/TVCard...ame=GT-U8000-RH latest driver Intel chipset dell laptop Graphic card intel 915gml Edited February 13, 2008 by domyrat Quote
Tjod Posted February 13, 2008 Posted February 13, 2008 Pleas Install the current Version 3.9.2.0 if this did not help post your support.zip Quote
domyrat Posted February 13, 2008 Author Posted February 13, 2008 (edited) ok, it works with new version next question is, how to get epg from a file, because i have a way to download EPG to a file and then load it (i used progdvb before and i want to use DVBViewer now). this is the program http://sourceforge.net/project/showfiles.php?group_id=39046 Edited February 13, 2008 by domyrat Quote
Tjod Posted February 13, 2008 Posted February 13, 2008 For XMLTV use "XMLTV Importer" (Mitgliederbereich) or Auto Import XMLTV http://www.DVBViewer.info/forum/index.php?...st&p=179966 Quote
