Audio problems.
Bubbi
OK,
here's another newbie question that i'm sure you all know how to solve for me.
My Eurosport channel has 2 audio streams..
As shown here:
The problem is that's it is 4 mono streams combined in to 2 stereo streams..
I can easily set it to play either left or right only.
But then there's ofcause only audio in me left or right speaker..
Is there anyway i can set it to play a mono stream out in both speakers ?
I wan't it to play "danish" in both speakers.
Hmm i still don't see a sollution to my problem..
As i said in my first post:
But that's not what i want..
I want to take the right side audio and put it out in both left and right speaker..
Not only the right one..
So i want the mono sound to be "fake stereo".. Which comes out of both speakers..
Can someone help me with that ?
Sorry :bye:, I forgot to mention that you had to look at Radlight "RLAudioSel.ax", that's what you need; but this is the post linked for this sw in the Memeber Area...
You can find some (few) other info at bottom of this topic...
Thnx for helping..
I seem to have some problems installing "RadLight Filter Manager"..
I've unrar'ed it into the plugin dir,
but i can't see the menu for it anywhere in the plugins in the player..
There's only a NetStream player..
The RadLight Filter Manager is no plugin, but a stand-alone application.
However, the current DVBViewer Pro 3.9.2 doesn't support using the RLAudioSel.ax (due to a bug). Will be fixed in the next version.
Hmm if it's a stand-alone program, why isn't there an exe file or something when i download it?
» Description: RadLight Filter Manager ( 944 Downloads )
» Version: 1.5 (Delphi 7)
» Size: 19 KBytes
» Last Updated: 05.06.07
http://www.DVBViewer.com/members/download.php?id=641
It's that one, right ?
But guess i'll have to wait for the next version of DVBViewer for it to work..
