Missing Video Frames bei der Aufnahme
SpecialK
Hallo, ich schon wieder :radscorpion:
Ich habe heute morgen einmal die 4 Folgen King Of Queens am Stück auf RTL 2 aufnehmen wollen.
Dank des Tips mit dem GraphSelector habe ich AV disabled, um Prozessorlast zu sparen.
Nun habe ich das fertige Ergebnis durch PVAstrumento laufen lassen und seht selbst meine log:
==DEMUXING==
Input: E:\Capture\10-20 08-25-00_RTL2 King Of Queens.mpg
AES: e:\10-20 08-25-00_RTL2 King Of Queens.mpg.mpa
VES: e:\10-20 08-25-00_RTL2 King Of Queens.mpg.mpv
FIXING startup delay.
FIXING stream synch.
ADJUSTING GOP timecodes.
Syncing: Cutting audio.
No integer frame match for A/V.
ALERT> 9 video frames missing at 00:38:42.640
ALERT> 10 video frames missing at 00:39:30.640
Syncing: Cutting video.
ALERT> 8 video frames missing at 00:39:33.040
ALERT> 12 video frames missing at 00:54:26.320
ALERT> 14 video frames missing at 00:54:51.760
ALERT> 9 video frames missing at 01:03:35.920
ALERT> 4 video frames missing at 01:03:49.840
ALERT> 12 video frames missing at 01:03:52.720
ALERT> 12 video frames missing at 01:17:18.640
ALERT> 10 video frames missing at 01:17:22.000
ALERT> 9 video frames missing at 01:23:48.880
ALERT> 8 video frames missing at 01:23:53.200
ALERT> 3 video frames missing at 01:23:59.440
ALERT> 6 video frames missing at 01:24:04.240
ALERT> 15 video frames missing at 01:39:06.160
ALERT> 4 video frames missing at 01:39:09.520
ALERT> 6 video frames missing at 01:39:11.920
ALERT> video frame missing at 01:39:28.720
ALERT> 12 video frames missing at 01:39:36.400
ALERT> 6 video frames missing at 01:45:52.720
ALERT> 2 video frames missing at 01:45:54.640
ALERT> 2 video frames missing at 01:45:57.040
ALERT> video frame missing at 01:45:58.480
ALERT> 12 video frames missing at 01:46:12.400
ALERT> 6 video frames missing at 01:47:05.680
ALERT> 15 video frames missing at 01:50:26.320
ALERT> 6 video frames missing at 01:50:28.240
ALERT> 11 video frames missing at 01:55:53.200
ALERT> 16 audio frames missing at 01:56:10.584
ALERT> Temporal structure wrong in GOP - dropping
Done.
Video bitrate: max 7547 , avg 3933 kbps
Setting first sequence header to avg. bitrate
Nun habe ich an den besagten stellen ganz unschöne Aussetzer im Film. Gut, ich gebe zu, man merkt es größtenteils nur, wenn man drauf achtet, aber man merkt es :rolleyes:
Liegt dieses ausschliesßlich an meinem vllt etwas schachen System (AMD 1 Ghz, 612 MB SD-Ram)?
Ich habe vergessen, Norton Autoprotect im Hintergrund zu deaktivieren. Kann dies mir die Fehler reingehauen haben?
Sollte die Videodatei nach Möglichkeit auf der selben Platte aufgenommen werden, auf der auch DVBViewer läuft? Oder sollte ich gerade eine andere Platte als Ziel angeben? Oder eine andere Partition auf der selben Platte? (Man, so viele Oder-Fragen...)
Bin für Tipps dankbar.
SpecialK
Hm, das sieht sehr schlecht aus. Welchen Sourcefilter hast du denn benutzt?
- SkyStar 4.2
- Marfi 1.1
- DVBSource
Bis dann, Oliver
ich denke mal, du meinst die unten als Bild angehängten Einstellungen.
Da habe ich den von Marfi genommen, welcher bei der Vollversion dabei war.
Btw: Die intelligente Pufferung steht auf 10%.
SpecialK
Wurde der Computer während der Aufnahme benutzt? Der DVBViewer ist bei dir auf normale Priorität eingestellt, d. h., er kann von anderen Anwendungen u. U. gestört werden. Versuche mal "höher als normal" oder "hoch".
Übrigens: Die Schaltverzögerung brauchst du nur, wenn du Tastatursteuerung benutzt.
Bis dann, Oliver
Hmm, ich habe tatsächlich einmal kurz meine Mails abgerufen. Aber nicht zu jeder angegebenen Zeit, in der ein Fehler aufgetreten ist.
Aber verdammt, das mit der Priorität hätte ich wirklich besser beachten müssen.
Naja, ich werde dann mal morgen wieder die 4 Folgen aufnehmen, die Priorität vorher höher stellen und diesmal die Finger weg lassen. Mal sehen, ob ich dann weniger Fehler rein bekomme :radscorpion:
Kannst du vllt was zu der Frage mit den Festplatten sagen, also wo ich das File am besten plaziere?
SpecialK
Die Aufnahme-Platte oder -Partition spielt eigentlich keine Rolle, nach Möglichkeit sollte sie aber nicht allzu sehr fragmentiert sein. Treten Fehler bei dir auch auf, wenn du A/V eingeschaltet lässt?
Bis dann, Oliver
Also direkt treten keine Fehler auf. Nur möchte ich a) lieber auf Nummer sicher gehen und stelle A/V bei der Aufnahme aus und b ) braucht ja nicht die ganze Zeit das TV-Bild laufen, wenn eh keiner zu Hause ist :radscorpion:
Ich dachte einfach, es könnte der Aufnahme gut tun, wenn der Prozessor nicht nur durch AV Wiedergabe belastet wird.
SpecialK
Es könnten auch empfangsprobleme sein. Nicht alles an fehlern sieht man beim live gucken. Die dekoder haben auch sowas wie eine verschleierung von fehlern (concealment). Beim muxen der aufnahme werden dann aber wahrscheinlich fehlerhafte frames einfach verworfen und die fehlen dann später.
Möglichst wenig am rechner ausser dieser applikation laufen zu haben, empfiehlt sich sicher immmer bei nicht so schnellen rechnern. Um ganz sicher zu sein, solltest du TS-recording mit dem feinen plugin von @Griga ausprobieren. Nachteil davon ist, dass es zusätzliche bearbeitungsschritte erfordert. Aber wenn's für einen guten zweck ist... :radscorpion:
Mit dem (Technisat)-Programm "SETUP4PC" -> "Status" kannst du sehen wie die Empfangsqualität ist. "SNR (dB) möglichst über 10, "BER" = 0.000000 und "Uncorrected Blocks sollten auch = 0 sein!
Den Tip von Henk halte ich für ganz wichtig. Vielleicht liegt der Fehler schon beim Empfang und wenn man TV4PC die ganze Zeit während der Aufnahme mitlaufen lässt sieht man das sehr schön.
Du kannst auch noch versuchen die ProzessPriorität (rechts neben VMR) etwas zu erhöhen und sehen ob was passiert.
Dann würde ich mal den Virenscanner und die Firewall disablen. Kann sein, dass die etwas dazwischen funken, denn schließlich wird die SS2 ja wie eine normale Netzwerkkarte behandelt.
Steffen
Ich hatte mal aufgrund einer bestimmten Tatsache (trifft bei dir sicher nicht zu) defekte Pakete. Von PVAS oder ProjectX wurden die nicht erkannt, allerdings waren sie deutlich zu sehen und wurden auch von Setup4PC angezeigt. Hier ist ein Beispiel.
Bis dann, Oliver
..ob dieser fall an übertragungstechnisch defekten ts-paketen liegt, ist schwer zu sagen. Ich glaube eher nicht. Die von dir genannten tools können solche fehler auch nicht erkennen, da sie nur die syntax aber nicht die mpeg-kodierung prüfen. Dafür sind andere tools zuständig (z.b. mprobe), die auch fehler im mpeg wie fehlerhafte macroblocks und slices detektieren können. Hier könnte es auch schon im original drin gewesen sein.
Im Originalstream waren die Fehler nicht enthalten, daher hatte ich auf die bestimmte Tatsache verwiesen (ein spezieller PCI-Bug in alten VIA-SB (<400)), der provoziert werden kann). Real hatte ich noch nie ein defektes Paket. Das Bild diente auch nur der Illustration, um den Fehler bei SpecialK auszuschließen, da dessen Fehler ja angezeigt wurden. Um solche Fehler auszulösen, müsste der Empfang schon katastrophal gewesen sein. Ausnahmsweise kann es nicht an der Kompatibilität von Marfis Filter mit dem Decoder liegen, da der Decoder bei deaktiviertem A/V-Rendering nicht aktiv im Filtergraph eingebunden ist. Anfangs waren solche Probleme mit dem Elecard Decoder üblich.
@SpecialK: Du kannst jetzt mit höherer Priorität noch einmal eine Aufnahme versuchen. Treten die Fehler weiterhin auf, solltest du mal über das Recorderkontrollfenster das Rendering abschalten. Alternativ kannst du auch mal den DVBSource Sourcefilter testen. Mit dem sind bisher keine solchen Fehler aufgetreten.
Bis dann
Ich bin nachher aus dem Hause und nehme während dessen mal etwas in vergleichbarer länge auf und werde das Ergebnis (also eher die Log-Datei) hier heute Abend posten.
SpecialK
==DEMUXING==
Input: E:\Capture\10-20 17-55-01_RTL2 King Of Queens.mpg
AES: e:\10-20 17-55-01_RTL2 King Of Queens.mpg.mpa
VES: e:\10-20 17-55-01_RTL2 King Of Queens.mpg.mpv
ALERT> 1 audio frame missing at 02:19:57.024
12 audio frame(s) missing at the end.
Done.
Video bitrate: max 7600 , avg 4063 kbps
Video: 209926 pics    02:19:57.040
Audio: 349877 frames 02:19:57.048
(Autosaving log to e:\10-20 17-55-01_RTL2 King Of Queens.mpg.txt)
Das sieht ja meiner Meinung nach schon mal seehr gut aus.
Habe die Priorität höher gesetzt, die Platte defragmentiert und den Rechner komplett in Ruhe gelassen.
Das waren wohl die Problemverursacher.
Vielen Dank für eure Ratschläge.
SpecialK
Das ist sogar optimal, es sind keine Fehler vorhanden. Die fehlenden Audioframes und die defekte GOP beziehen sich nur auf das Ende der Aufnahme, das ist normal, da die Aufnahme eigentlich immer in einer GOP unterbrochen wird.
Bis dann, Oliver
Da bleibt mir nur noch zu sagen:
Vielen Dank für eure Tipps und Ratschläge.
Danke,
SpecialK
