Satellite Scanning in NA with Twinhan 1020
Fantasma
Hi guys,
I am a registered user of DVBViewer for more than a year now, but I had stopped using the application when my Skystar 2 was replaced by a Twinhan 1020.
Several days ago I downloaded the latest version of DVBViewer, and since then I have been unable to scan two satellites in North America, being reading the forum for days, and everything tells me I am not alone, cause other users are reporting the same issue.
The DVB card is recognized by DVBViewer after I registered the file thsource.ax, but after trying for days to scan, the application reports that zero program(s) were found.
The same problem occurs with TransEdit, my dish is connected to a Diseqc Switch with 4 ports, two Universal KU band LNBs are connected to this switch. Everything is smooth when I scan using ProgDVB.
I am using Non BDA drivers (WDM instead), is there anything I could do ?
Thanks in advance
Hello,
the support for WDM drivers is removed in DVBViewer.
you need also the bda driver for your card.
Hello,
Hello,
Thanks for answering.
Are you saying that if I install the BDA drivers DBVViewer will work?, all of the other applications I use work flawlessly with the WDM drivers.
Hello,
if you install the current bda driver for this card, DVBViewer will be work.
only you must do a new device scan in options -> hardware.
the best is, you make a recovery point for windows. if anything not working you can get back.
I appreciate you took the time to look into my problem.
My setup is working very nice with other applications, I will have to think about it before I proceed, I guess I will have to take the chance.
Gracias.
F
