bastjuan Posted February 17, 2008 Posted February 17, 2008 Hi, Sorry for my english. I have : - [satellite] Technisat Multytenne - Skystar USB - DVBViewer Pro I haved tested the Technisat Multytenne with a TV installation and all is OK. But I have a problem with the Skystar USB and DVBViewer. - Astra 19.2°E : OK - HotBird 13.0°E : not OK When I scan the HotBird Channels, when I scan the HotBird Channels, I found only some ASTRA channels (51). Must I configure server4PC with DVBViewer Pro ? Is DVBViewer Pro compatible with Multytenne or Skystar USB ? Must I configure the DiseqC in the DVBViewer Pro ? If yes, where ? Thanks very much for your help. JLB Quote
hdv Posted February 17, 2008 Posted February 17, 2008 Hello, Must I configure server4PC with DVBViewer Pro ?no, it can removed from autostart.there is only needed if you use internet over satellite. Is DVBViewer Pro compatible with Multytenne or Skystar USB ?yes. which driver you use? the bda or wdm driver?for best results use the wdm driver, only with this diseqc is possible. Must I configure the DiseqC in the DVBViewer Pro ? If yes, where ?yes. i don't know which sat is on which position.the best is you test the four option (Pos A/Opt A, Pos B/Opt A) and so on. Quote
Griga Posted February 17, 2008 Posted February 17, 2008 I'm using the Multytenne with good results (though not with a SkyStar USB). DiSEqC must be assigned in the following way: A/A Astra 19° E B/A Hotbird A/B Astra 23° E B/B Astra 28° E Go to Channel -> Channel Editor. Select the root folder with the according satellite position and set DiSEqC on the right. Quote
bastjuan Posted February 17, 2008 Author Posted February 17, 2008 Hello, Thanks for your help. I have configured the diseqC : A/A Astra 19° E B/A Hotbird A/B Astra 23° E B/B Astra 28° E (thanks Griga) Then I have downloaded the lastest drivers (4.4.1.0) and I have installed the WDM driver. Astra is always OK. But the scanning of the Hotbird channels is not OK : only 61 programs found... I will start again at 0... Quote
