preview problem
anaxx
Hi all i am a new happy user of DVBViewer 3.9.2.0 thus i have a litle problem with the preview window:
I pop it up normally but when i right click on it for its menu, it closes so i can't work it.
Any ideas?
Any ideas?
Just be happy, that is how it works. (press F8 and select Help, you can see which commands are valid for PIP)
Edited by IRa
Thanks for the answer.
I know how it works ,i worked it in DVBViewerGE.
In DVBViewer 3.9.2.0 the preview window opens but right cliking on it ,it closes, no context menu, nothing.
Anybody with the same problem?
The way DVBViever Pro manage the preview -as you surely already know - is completely different from the way GE does: GE have a completely different OSD; so there isn't any problem with that, it's the Pro standard behaviour, you like it or not...
