Jagagbe Posted February 21, 2008 Posted February 21, 2008 Hey So I have really weird problem with DVBViewer.....I have installed terratec cinergy 1200 cabel card with newest BDA drivers. I have purchased newest DVBViewer and installed it correctly to my pc. When I had installed DVBViewer program finds my dvb card and starts to search channels. It found all the channels and they worked just fine. But when I rebooted my computer and started up the DVBViewer and it says "device not found". I go to the program settings and when I choose the device list I see the terratec device and when I press "Refresh" button the dvb card disappears from the list. When I would be able to see device in the list again, I need to reboot my computer and then press refresh again and then the card shows up again to the device list. If I repeat the process again about 3 times I might be able to see television for a few moments. Then the card disappears again. What is solution for my problem?? It is not nice to pay from the software and the it doesn't work with my card, even if my card is on the supported device list allready. Quote
