h.264 codec on MPC instead of DVBViewer
Zori
Hi All,
The TV program I recorded using DVBViewer can be viewed using Media Player Classic. But unlike viewing under DVBViewer, MPC uses over 90% CPU time to decode it.
Is there any way to map the PowerDVD h.264 codec on MPC? So it can be view the .ts file at under 20% CPU time like DVBViewer does? Thanks in advance.
Regards,
Richard
Well you should ask this in a mpc forum. Or try using google. :wacko:
Hi All,
Regards,
Richard
yes you can use your own filter in MPC
go >0ption >External Filters > Add Filter ......
you even can use 10 different renderers in the output section
For HTPCs try the MPC - Cinema edition (Build by Casimir)
Best
m
Edited by vonMengen
Best
m
I tired.
I added CyberLink H.264/AVC Decoder in External Filters. and set as "Prefer" but still the CPU Usage is over 85% when viewing HD .ts file.
