Chris Diak Posted February 23, 2008 Posted February 23, 2008 Hi all, I recently updated to version 3.9.2 and [removed] isn't working! Actually even my main real subscription isn't working! I think I need ersion 3.9.1, but it is impossible to find it. Any halp? Thanx a lot!
Lars_MQ Posted February 23, 2008 Posted February 23, 2008 just setup the 3.9.2 correctly and it will work. No support of or for old versions.
Chris Diak Posted February 23, 2008 Author Posted February 23, 2008 just setup the 3.9.2 correctly and it will work. No support of or for old versions. Can you please define correctly? I have installed the new version without uninstaling the 3.9.1. Do I have to uninstall the 3.9.2 and then install it back? If yes, is there a way to backup my settings? What I really need is the keyboard shortcuts which are associated with my remote control. Thanks for your support!
Lars_MQ Posted February 23, 2008 Posted February 23, 2008 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210
Lars_MQ Posted February 23, 2008 Posted February 23, 2008 well forget my previous posts. No support for illegal plugins. Thread closed.
