MomoBrut Posted February 23, 2008 Posted February 23, 2008 On my friend's PC everything works fine with DVBViewer except playing DVD from HDD. When he try to play a *.ifo file, DVBViewer always freezes. When he try to play normal DVD, it works flawless. The DVD backup is ok, because PowerDVD has no problem to play it from HDD. Thank you for your help. Quote
MomoBrut Posted February 23, 2008 Author Posted February 23, 2008 On my friend's PC everything works fine with DVBViewer except playing DVD from HDD. When he try to play a *.ifo file, DVBViewer always freezes. When he try to play normal DVD, it works flawless. The DVD backup is ok, because PowerDVD has no problem to play it from HDD. Thank you for your help. Additional info - *.vob files are playable without problems ... Quote
MomoBrut Posted February 25, 2008 Author Posted February 25, 2008 (edited) Update - I buyed DVBViewer for myself yesterday. And I have the same problem as friend of mine have. I try to play DVD from HDD, it always freezes. After more testing I found out, that it is not application hang up. When I try to open .ifo file, it always looks like hang up, but that is only for first sight. After some delay DVBViewer normaly starts to play the DVD. It takes about 1 to 4 minutes of delay (the amount of delay is quite random), when DVBViewer do not responds to any action. After this delay everything forks fine ... Can anybody help me? Or anyone expirienced the same problem? Edited February 25, 2008 by MomoBrut Quote
MomoBrut Posted February 25, 2008 Author Posted February 25, 2008 Another update ... :-) The problem is with SATA HDD WD 500 GB. When I disconnect this HDD an use another HDD with DVD backup, it works without delay ... The same dalay has WMP also. I will try to find out, what is the problem with HDD. Strange thing is, that PowerDVD has no problems at all ... Quote
MomoBrut Posted February 29, 2008 Author Posted February 29, 2008 Another update ... :-) The problem is with SATA HDD WD 500 GB. When I disconnect this HDD an use another HDD with DVD backup, it works without delay ... The same dalay has WMP also. I will try to find out, what is the problem with HDD. Strange thing is, that PowerDVD has no problems at all ... Problem solved ... do not know how ... I replaced HDD with other HDD several times, disabled indexing, enabled caching and finally used another SATA connection on MoBo and it works now without delay ... Quote
