MP3 Filter settings for playing MP3 files
digidigi
How is DVBViewer handle playing MP3 files, does it use an build-in filter or external filters?
I have a few songs that gives me error "0x80040217".
Thise mp3 files play fine in all my other players, (VLC, MM Media Player, Mediaplayer Clasic).
Is it anyway I can edit some filter parameters in DVBViwer for MP3 files?
PS. I'm using the latest version 3.9.2 on XP SP2
Thanks,
Digi
DVBViewer does not handle at all. It let's windows directshow handle the playback.
Thanks Lars,
Any sugestion how I can fix this, I mean it should work since it works just fine in MS Media Player.
I have tried to remove all codecs I don't need with no luck on this issue.
Is it any tool I can use to check, set the default MP3 filter?
/Digi
Possible reason: A standard DirectShow component for MP3 handling (MPEG-I Stream Splitter from Microsoft) is not able to detect the MP3 content in a file, mostly due to huge ID3 tags at the beginning, containing an album cover as image or such.
This can be solved by installing the MP3 Parser Filter.
The View -> Filters menu in DVBViewer shows which DirectShow filters are actually used for playback.
Wow Thanks,
I installed the filter abowe, and now it works as dream :blush:
