DVBViewer Pro 3.9.3.xx beta
Lars_MQ
In the Betasection of the Membersarea is a new beta of the DVBViewer Pro.
This is a beta! So don't use it as a produktion system.
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :blush:
Register the new Shoutcast filter by running filters\regfiltervod.exe.
Please post all reports to the english or deutsch beta forum.
Version BETA 3.9.3.0
  • VMR7/VMR9: Reworked the osd zoom handling. Please check with nvidia fix disabled and enabled!
  • OSD: Added: EPG events within the timeframe of a timer are displayed in a different color.
  • Favourites: Fixed a problem with more than 99 favourites in a group.
  • Channellist window: Now audiosubstream are marked as selected instead of always the mainchannel.
  • EGP Window: fixed bug in TVGuide, it got sometimes confused with audiosubchannels.
  • OSD-Mini EPG: Fixed no data available shown after starting the DVBViewer.
  • New Device and Tunertype: IPTV. For channel scanning please use the iptv transedit beta from the membersarea!
    To add the device to the DVBViewer edit the usermode.ini in the DVBViewer program folder:
    [CARD]
    IPTV=1
    start the DVBViewer and do a manual device scan in the hardware options. Remember to setup the device correctly!
    Known issue:
    The IP is not displayed as readable IP in the channeleditor and the scanwindow.
  • Visuals: Fixed visuals ignored the OSD-Offsets.
  • Hardware handling: If a BDA device is unplugged (usb/firewire/pci) before/while DVBViewer is running, it will be marked internally as not available and is not used.
    If it is plugged in again, it will marked as available and is used if required.
    To make this work, the device has to be in the hardwarelist of the DVBViewer.
    ATTENTION: Avoid removing devices while in use. Some drivers can cause tthe system to crash (fireDTV firewire is quite unforgiving :bye: ).
  • Hardware handling: If a error occurrs while trying to open a device, the device is ignored and the viewer will try to find another fitting device.
  • File playback: Fixed playback of mpeg/ts files without DVBSource filter.
  • Preview: Fixed close preview disabled sometimes the volume in the main window.
  • Preview: Change: If VMR9 is not selected in the preview options and OS=Vista the preview uses the evr renderer as default.
  • Preview: New handling: sound swap = OSD-Red, picture swap = OSD-Green. the number keys are not used anymore.
    You can reactivate the old (number keys) handling via OSD-Blue -> Key move Mode. This option is persistent.
  • Audioselect filter: Does work again.
  • DesktopTV: Changed the DesktopTV method to work with vista64.
  • DirectX Options: Changed name of video renderer "unchanged" in "system default renderer".
  • CI-Support: Fixed AAC was not taken into account when building the caPMT.
  • Recording: New Option Adjust PAT/PMT.
    If activated this options causes the DVBViewer to generate a PAT and PMT in TS recordings, which does reflect the present streams.
    The PAT only contains the recorded service and the PMT only the recorded ES Streams.
    This option may help with playback hardware/software which is not able to cope with the unchanged Tables for ts.
  • New shoutcast filter.
  • Change: If no setup.xml is found the wizard is started automatically.
  • Updates to several language files.
  • Several small fixes.
    Netstreaming Plugin:
  • Changed settings handling. Settings are now saved in the userdata folder /plugins/netstreaming.ini. Old settings will be converted on first use.
  • 3 weeks later...
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :radscorpion:
Please post all reports to the english beta forum.
Version BETA 3.9.3.10
  • PAT/PMT Adjustment: Tweaked and optimized some more. If the SID of the channel in the channellist is not correct, it will deactivate itself and use the original PAT/PMT.
  • Channelscan with Update: fixed bug: channels without audiostream where simply added instead of updated.
  • IPTV device: Does automatically detect if RTP or pure UPD is used.
  • IPTV device settings: Removed RTP checkbox (see above).
  • OSD-Zoom settings: Reworked remote/keyboard handling. See OSD helppage (OSD-Blue -> help).
  • OSD-Zoom settings: Fixed some bugs. H/V was mixed up. Default didn't work correctly, Recall didn't show the current zoompreset.
  • KNC BDA Device. Integrated new KNCBDACTRL.dll. Should fix the problem 2KNC / 2CAMs (untested). DO NOT MIX THIS DLL WITH AN OLDER DVBViewer VERSION!!
  • BDA Devices: Tweaked the simple DiseqC handling for some cards.
  • Lng Dateien: Deutsch and English updated.
  • Added new symbolset (nightlife) for the toolbuttons. Thanks @Rago.
  • ATSC - CC fix from Christian integrated.
  • DVB-Subtitles: tweaked and optimized a little bit. Please test.
  • VCR: fixed small memoryleak introduced in the last beta.
  • VMR7/VMR9 windowed mode (aka VMRFix): further optimizations/correction in zoom handling.
  • VMR7/VMR9: fixed bug: OSD disappears if the DVBViewer window is moved from one monitor to another on multimonitorsystem.
  • VMR7/VMR9 windowless mode (aka NO VMRFix): a new option added in the DirectX settings "YUV Mixing mode". Can be used instead of VMRFix.
    Does use DXVA if possible and does handle the OSD the "normal" way (means the OSD is not limited to the videoarea). Please test.
  • Hardware handling: If a device can not be opened/started (because it is used by another software) the DVBViewer tries to find another useable device.
  • Netstreaming Plugin: PAT/PMT Adjustment integrated. Is not active if stream whole transponder is selected.
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :(
Version BETA 3.9.3.15
  • OSD: the Menu Control has a new attibute "SelectedColor", ignored if 0 or not present, otherwise shows the focused text of the menu control in this color.
    The Label Control has a new attribute "Shadowcolor". Default is black ($FF000000).
  • Preview: Preview is not closed anymore if fast channelswitch is not activated.
  • Preview: Preview is not closed anymore on starting mediaplayback. Sound can be exchanged, video not.
  • MultiCPU: Removed MultiCPU activation from playbackstart of the renderer and put it in a better place.
  • EPG Window: if "show recording window after programming" is selected in the options the last added EPG entry via "send to pvr" is selected in the recording window.
  • Can tune Filter: Changed behaviour. If activated it will applied permanently not only on recordings. Filters DVB-S2 channel, if not DVB-S2 card is present ect.
  • EPG Window: Timeline now shows EPG entries which fit a planned recording in red.
  • OSD-Playlist: the Album images are now shown.
  • OSD Thumbnail images: reworked search for fitting image strategy.
    1. search picture with name of file with extension changed to jpg.
    2. If 1. failed seach for "folder.jpg" in the folder of the file.
    3. NEW: If 2. failed search for any jpg file in the folder of the file.
    For folder images the procedure starts at 2.
  • Tweaks setup.xml(for now): Sections 'Musicfiles', 'VideoFiles', 'Pictures' have a new entry 'Defaultview' (0-2). Determinates which view (list (0), small (1), big (2) thumbnails) will be used as default.
  • Preview: Fixed Memory leak. Introduced last beta version.
  • Playback Dynamic jump: the last beta had a 4 minute jump instead of 5, corrected.
  • Netstreaming Plugin: Fixed sometimes wrong Configfolder used (introduced last beta).
  • OSD Delete File Dialog: Filenames are now shortened the windows way.
  • Serveral improvement for chinese and other languages with non western charset in the EPG window.
  • MultiCPU workaround (see tweaks.txt).
  • Osd Menu Optionspage: shows the translated text of the menu items. Some items must be translated via the lng files [OSD] part. see the OSD logs files for them (set debugmode for OSD <10).
  • Screenshot: Filenames are now calculated in a better way.
  • Screenshot: Added Tweak:
    Value: Screenshotformat
    Section: General
    Accepted: clipboard, png, gif, jpg, tif, bmp
    Default: png
    Description: Determinates the format a screenshot will be saved in.
  • Multiple instances for non Admin Users (also Vista - "I think I'm admin" Users :D ): a multiple DVBViewer installation didn't work because the COM server tried to register itself with not enough rights.
  • Timeshift options: free diskspace is shown for the selected timeshift folder.
  • DVD Playback: Changing the audiostream via OSD resulted in a redundant audiomenu display. Fixed.
  • lng files updated. Changed tunertyper IPTV to DVB-IPTV.
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :wacko:
Version BETA 3.9.3.25
  • Fix in OSD Controls -> thanks @markusk for pointing out the missing times in his skin.
  • OSD Videowindow: Reverted to the old way of generating thumbnails.
  • Options/System: current Username button inserts the username into the taskscheduler field.
  • Moved the Tweaks for defaultview of OSD movie, music and pictures to the according optionspages.
  • Placed all screenshot settings from tweaks into the general options page.
  • Added option Use EPG for screenshot filename. Workaround for chinese users until there is a solution.
  • Options: Move the Picture extentions setting into the Picture General page.
  • Wizard: Added EVR to renderer selection.
  • Wizard: Added DVB-S2 capable device and new tuning method to hardwarepage.
  • Bdadevice/TT CI: Fix for wrong elements calculation in CAM callback function. For most users this never has been a problem.
  • Bdadevice/TT devices: moved deinitialization of the device in front of graph teardown. Maybe this helps with CAM only works 1 out of 2.
  • Language files: Updated. Attention Français and Italiano files are updated with the picture extentions move. For further translation please use the files from this zip.
  • Fix: Newsfeeds update: no more delays if page is not reachable.
  • Fix: Crash on exiting DVBViewer while radarimage from weather page was active.
  • Change: The channellist now syncronize their filtersettings at once.
  • Fix: DVD Playback: The OSD Audio menu was show twice.
  • Change: EVR does not need yuvmixing setting anymore for correct zooming. EVR ignores vmrfix setting now, no need for it anymore.
  • VODFilter: Fixed problems with some shoutcast streams.
Installation:
Version BETA 3.9.3.26
This is kind of a hotfix. Thanks to testings done by @cinch, I have hopefully found the reason for the TT 3650 not initializing the CAM everytime. Please test it.
For all who downloaded the 3.9.3.25 but don't have a TT device, there is nothing new in this beta compared to the 3.9.3.25 so you don't need to download it.
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. <_<
Version BETA 3.9.3.30
  • - Fix: DVD Playback: AC3Filter sometimes connected as videodecoder.
  • - Fix: videoplayback did not take EVR into account.
  • - Optimization: Small optimization for VMR/EVR OSD Filter.
  • - Fix: Rebuild Graph: the audiochannel display was not updated correctly.
  • - Change: the hintwindow now uses the setting for windows hint font.
  • - Some updates for the language files.
  • - Change: The radlight audioselect plugin is not supported anymore. Instead an internal version is used (thanks @griga).
  • - Several small fixes and optimizations.
  • - Reduced debug logging a little bit.
I've take down the current Beta for now, because there is a problem in there.
Until I upload the new Beta: Please don't activate the "Adjust PAT/PMT" option for recordings.
This is a beta! So don't use it as a production system.
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. ;)
Version BETA 3.9.3.35
Attention! Please backup your channels.dat and tvdatabase.db for this beta!
  • fix: PMT was not found by the DVBViewer on fileplayback of recordings done with Adjust PAT/PMT option.
  • Change: graphedit now shows the name of the device instead of "BDA Device".
  • Add: The VODSource Filter now also handles AAC streams.
  • Big change:
    The Audio channel per channel, Volume per channel and EPG-settings (EIT, intern, extern) are no longer stored in the Database. Instead it is stored in the channels.dat.
    On first start the old settings are converted and the database tables removed. The handling for the users does not change.
    If you use the recording service you'll need an updated version.
Installation:
Version BETA 3.9.3.40
  • Fix: Several of Grigas enhancements for ts-fileplayback with multicore CPUs please test.
  • Change: Recently used Channels list (deutsch: Kanalhitparade) does show now the last 10 recently used channels (channelhistory). They are stored to disk and restored on next start. To disable this see options -> TV+Radio.
  • Change: A new config file named userdata.xml is used. It will/should contain all userprivate data (channelhistory, urlhistory etc.) and will not be included in a support.zip. More data from the setup.xml will migrate userdata file in time.
  • Add: Chinese EPG for Taiwan.
  • Change: The OSD-Recording list is now sorted descending on sort by date.
  • Add: VOD-Filter can now record the played media.
  • Fix: Send to vcr from Timeline did ignore the audiosubchannels.
  • Optimized: AYUV color conversion for OSD now much faster.
  • Fix: Changing the OSD skin in the options now triggers a graph rebuild in VMR/EVR mode.
  • Add: Infofile for recordings: the used device is now written into the infofile.
  • fix: Playback of a running recording with "Use DVBSource for file playback" deactivated caused a error message. Now the DVB-Source is always used in such cases.
  • Fix: TS/Mpeg playback without dvbsource showed the wrong audiochannel count.
  • Fix: TS/Mpeg playback without dvbsource miscalculated the aspectratio.
  • Reworked: Aspectratio handling of VMR/EVR if ratiosettings <> auto.
  • Change: Now Channelnames with more than 25 chars a possible. You need to input them manually or do an update channelscan to get them into a present channellist.
    Please check your favourites and timers if you change the channelnames!
    Don't use the following tools until they have been updated, they will cut the long names back to 25 chars:
    - Transedit
    - Channellist editor
    Tools only reading the channellist like tvinfo or tvgenial plugin should be checked too, but can't harm the channelnames. Logonames must be updated also.
    The COM interface should also have no problems.
    In short: let it grow in time, don't force long names, test it but leave your needed channels alone until all tools are updated. :bye:
Installation:
Version BETA 3.9.3.41
Hotfix for broken playback of ts files
The matching DVBServer 3.9.3.41 for the DVBViewer Pro Beta is in the Membersarea.
Changes:
- Uptodate with the hardware handling of the DVBViewer Pro Beta.
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. >_<
Version BETA 3.9.3.45
  • Fix: Several enhancements for fileplayback with multicore CPUs (again).
  • Fix: VODSource did not play some shoutcast radios.
  • Fix: On some chinese channels the aspectratio was not detected correctly.
  • Fix: Channeleditor: Assigning DiseqC setting for a group of channels did not work for subchannels correctly.
  • Fix: The wizard counted audiosubchannels as channels on scanning.
  • Fix: regfiltervod.exe did sometimes fail to register the filter.
  • Fix: VODSource sometimes did not set the file extention correctly while recording to a file.
  • 3 weeks later...
Installation:
You need a working DVBViewer Pro 3.9.2.0 Installation. Make a duplicate of the DVBViewer folder and extract the beta into the duplicate folder. Make a Backup of your datafolder. If you don't know where your data folder resides DO NOT USE THE BETA. It is for advanced users only and not suitable for beginners. :idiot:
Version BETA 3.9.3.50
  • Change: Scanwindow: Shows now more entries in the drop down lists.
  • Fix: Channeleditor: Now empty Audiofolders are displayed and items can be dropped into them.
  • Fix: Channellist: Doubleclick handling rewritten. closing a channelfolder with double click shouldn't cause anymore channel switching.
  • Change: Channellist: On entering the search criteria field with a mouse click the entry is selected. Double clicking the entry will clear the search.
  • Change: Channeleditor: Now changing the Channelgroups can be done for whole channelfolders via the right click context menu.
  • Change: Stop and deleting running recordings, which are played back, will result in a playback stop so the file can be deleted correctly.
  • Change: Deleting recordings while playing them will result in playback stop so the file can be deleted correctly.
  • Fix: VODSource did not playback some web radios correctly.
  • Change: Weatherdata is now received again. You need an updated OSD-Skin for it, otherwise you get a warning. The update for the default skin is part of this archive.
    For OSD-Designers: You need to place a 61x61 button with the ID 500.
  • Fix: Reloading the channellist via transedit did not update the channel editor.
  • Change: Changed the naming of the options in the Network devices settings dialog to more meaningful text.
  • Change: Channelhistory shows the last channel on top instead of the current.
  • Fix: The OSD Recording symbol was not shown in full screen mode.
  • Change: Hardware Options: now settings are disabled if they can't be used with the selected device.
  • Fix: Jumping over the end of a growing file (recording) caused a stop in playback.
  • Added: Tweaks: closeRecWin and CloseEPGwin added (see tweaks.txt). closeRecWin determinates if the osd is closed after selecting a recording for playback. CloseEPGWin determinates if the osd is closed after selecting channel in one of the epg windows.
  • Changes: PiP: when swapping channels no miniepg is shown anymore. when audio is swapped the saved volume level of the main channel now will be ignored.
  • Changes: PiP: AAC is now supported.
  • Fix: PiP: several small fixes and improvements.
  • Fix: OSD-Timeline: The templates for channel name and time are now correctly used. You can also influence if the second data row is shown by deleting the templates (ID: 23 and 30).
  • Update: Updated several language files.
The matching DVBServer 3.9.3.50 for the DVBViewer Pro Beta is in the Membersarea.
Changes:
The hotfix version 3.9.3.51 is in the membersarea.
Fix: DVBSubtitles didn't work correctly.
Sorry about this. :idiot:
The Beta test is closed. We will publish a new Release (hopefully) within the next two days. ;)
