EPG Scan and Export
reuzzli
I just wondered if it is possible to add a funktion that scan all transponders and read the EPG-data out of the streams, save them and made an html-tv-magazin.
I know that it would takte some time to scan all channels, but it would be easier than to view a channel on one transponder and let DVBViewer load the epg and afterwards use the epg-2-html-plugin to create the html-magazine...
A solution that automatises creating a TV Guide already exists. See here.
Griga
Hi Griga,
thanx for your answer! the script works very well! hope that the edit of the CSS will be available quite soon. thanks a lot!!!
:jump:
