Question - Can you use
rich110
I am a new user of DVBViewer (in fact I'm still waiting for my login email to download the pro-version after purchasing today).
I have a question... All my TV channels are received via satellite, and I currently get most of my EPG data (for 5-7 days in advance) directly from the satellite streams. However, I have 2 channels that only receive "Now and Next" EPG data via the satellite stream, so I currently use an XMLTV data source to get a more complete set of EPG data (5 days ahead) for these 2 channels.
Q. Can I use "mixed" EPG data sources (satellite stream and XMLTV) to populate a single EPG in DVBViewer?
I hope this question makes sense.
Cheers
Rich
Yes this question makes sense and the answer is yes, you can select per channel or satellite if you want to use the transmitted EPG or the imported one. I would also recommend using AutoImport XMLTV by Delphi .
