Media info in OSD duration.xml
MomoBrut
Is it possible to display the track number in duration.xml ? I found #Media.Title, #Media.Album and #Meida.Artist, but I need to see a track number ... it is detail, but this will be very helpfull.
Edited by MomoBrut
  • 4 years later...
use #Media.tracknumber
Hi Lars
How do you show media date?
For example - Date of recording (as shown in recording list)
How do you show media channel recorded?
For example - Channel recorded (as shown in recording list)
Thanks
Tony
  • 4 weeks later...
Hi Lars
Thanks
Tony
Hi
I want to show the thumbnail for recording being played, similar to #coverart for music files.
Is there a reference that will call the right thumbnail (assuming it has been created)?
I guess the logic is
if music file, use #coverart
if video file, use #recordart (or whatever its called)
..to be really clever, it could then use FilmInfosPics.exe to try to find an online thumbnail for the TV series or film.
...or could show the channel logo the recording was recorded from.
I know what I want to achieve with the logic above, and have got some way into xml to adapt myminiepg.xml into a decent duration.xml.
I dont know the references to make this work, or the xml script to do this.
Is it possible to show the date of the recording?
The date appears in the recorded TV list, so I guess there must be a reference for this someplace.
Is there a list of all available references for xml?
Please find duration.xml file attached for reference.
Its based on myminiepg.xml - bl4ck_HD_miniepg_overlay_1920x1080_1.8 LITE
Uses Connicity 3D and bl4ck_HD_miniepg_overlay_1920x1080_1.8 LITE images.
Would be great to get this working
Also - when I delete a recording from OSD list, is it possible to also delete the 3 related thumbnails at the same time?
duration.xml
myMiniEPG.xml
Edited by xtonys
